Firebird 6" thick parts book
#51
Re: 89 WS6 wheel centers
Originally posted by LIDNR2
Hi Josh, Jim here, would you be able to tell me the number for a 1989 Formula 350 w/ WS6 silver wheel center cap. I lost one with the black WS6 logo on it and can't find it any where. My car only has 16,000 miles on it. thanks in advance.
#53
Car: '89 Formula 350, T-Top
Axle/Gears: Stock 3.73's
center cap
Thanks Pal. Allthough, I'd bet any money their discontinued. Thanks again.
#54
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
me again.
i don't even know what it's called. it's the little bezel that holds the fog light switch (also holds hatch pulldown button on hardtops i think). i've seen on older birds where it's actaully connected to the dash, but on mine it's a separate unit altogether. so i hope the pic helps somewhat.
#55
underdave, here is what i have in my book:
10095231 - (w/C49; w/o A90 & T96)
10095232 - (w/A90)
10095233 - (w/A90, C49, T96)
C49 - Rear Window Defogger
A90 - Electric rear hatch release
T96 - Fog lamps
10095232 - (w/A90)
T96 - Fog lamps
#56
Engine: 305 TBI
Transmission: auto
so nothing with T96 but without C49 or A90 huh. that sucks. i must have a rare one (yeah, not really). does it even say what the piece is called?
oh yeah, and thanks for looking for these for me/us.
#58
Me again. How about a part number for the pad on the clutch pedal?
#59
underdave - here is exactly what it says for all 3 panels that it lists from left to right accross the page:
PANEL, I/P ACSRY SW(PAINT TO MATCH)......90-92.....F(C49)(EXC A90,T96)........10095231
PANEL, I/P ACSRY SW.................................90-92.....F87(A90).........................10095232
PANEL, I/P ACSRY SW.................................90-92.....F87(A90,C49,T96)...........10095233
The only thing I can't figure out is what the "F87" means. It doesnt show up as an RPO definition in my book nor on the RPO decoder on TGO. So I am run out of ideas on what it mean. There are many others like that in my book such as "F67" and just plain "F".
82firebird - Front bumper cover - 10020286 N/A @ GMPD*
TimRS - I don't know what year bird this pad is for so here is all years:
(82-83) - 14038638 N/A @ GMPD*
(84-91) - 14009148 $5.81 @ GMPD
(92) - 14038638 N/A @ GMPD*
*=check local dealers to see on availability.
#63
Originally posted by 83firebirdS/E
How bout a Power Antenna for an '83 bird?
#65
Car: 1983 Firebird S/E
Originally posted by joshp14
Sorry about not replying right away, I am at home on the weekends (book is at dorm). I didn't find a power antenna for 83...
Thanks again.
#66
Hmm, that's strange my '83 has the power antenna from the factory. Do they have a power antenna number in there for any third gen year?
Thanks again.
Thanks again.
Man this makes me mad, this is the only thing I havent been able to find.
You may have to call GM on this one...
Sorry man.
#69
Originally posted by omnipotentgoku
Just realized that it was a book of birds... the felts should be the same nevertheless right ?
if so then the # is 20192983 (1982-1987) and runs....holy ****...$12.38 each from GMPD and lists for $20.97!
now i am thinking twice to make sure i have the right part. looking...looking...yup...right part. it tells that it requires 4 of them per car I think. They were only $3.25/each when this book was printed!
I also assume that this part includes the felt on it cuz it is the price for the little bracket that holds the felt, and the felt itself. There is no separate p/n for the felt. I think your best bet is to grab some from a boneyard, ebay, or get some felt of your own.
BTW, GM calls it a Window Guide Stabilizer
-Josh
#71
Engine: 305 TBI
Transmission: auto
how about the little hook and giant washer thingy that hold the spare tire to the sheetmetal for '92 vert?
by the way, like everyone else has said, you're a pimp for doing this.
#72
1) Wingnut - 9785616
2) Rubber Spacer - 10039021
3) Adaptor (big washer) - 14030631
4) J-Bolt - 10042601
Hope this helps Dave, if not let me know.
Josh
#74
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
i need my driver side and pass side air duct for 84z l69 ho thanks
#76
Originally posted by jocww
o and the hoses or ducts or what ever u call it
#77
i dont know i got them jacked or lost well one was jacked one was lost so i dont know. i hate u for being the first on teh second page
#78
#84
each duct or each piping
#90
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
How about the lockplate retaining snap ring for an '88... non tilt steering column
#93
im guessing no prices
just call a local GM dealer and ask them or go to www.gmpartsdirect.com and see what they charge.
#95
1 Post
Car: 1987 Trans Am
Engine: Lt1
joshp14, So from an earlier post, you can't find part numbers for a power antenna? How about for non-power for an 87. I need the whole thing-antenna and base to where it plugs into the radio. Also, how about the bezel that goes over the radio and heater/a/c controls? Thanks a million.
Edit: Last part...the plastic wheel well pieces would help.
#96
83firebirdS/E -
Lock cylinder - 20496717
LC pawl - 20308544
LC Retainer clip - 12337954
LC Clip - 20650814
the pawl is the tab that connects to the inside of the lock cylinder - it is that part that keeps the door from being opened.
Trans Am#5
Radio Bezel - 10034187 (w/C67)
- 10034186 (w/o C67)
For the antenna info, I'm including everything you need....it's as if you dont have any of the parts. Also, is the L-Bracket already in the fender? It's the bracket that holds the base of the antenna.
Antenna - 10136715
Nut - 22549794
Bezel - 12337870
Antenna wire(to radio) - 10026633
Mounting Hardware (if applicable)
Bracket - 10017211
Screw (bracket to body) - 22506732
Screw (antenna to bracket) - 11508797
I assume that when you say 'plastic wheel well pieces,' you mean the little plastic nuts that snap into the body, and then the big plastic screws screw into.....?
If so, the P/N is 20370594. They are $.60/each but must be bought in packages of ten I believe. Source: GMPD
LC pawl - 20308544
LC Clip - 20650814
Trans Am#5
Antenna - 10136715
Nut - 22549794
Bezel - 12337870
Bracket - 10017211
#97
1 Post
Car: 1987 Trans Am
Engine: Lt1
Thanks...What would w/c67 be? By the plastic for the wheel well, I meant the actual wheel well itself. Attaches to the fender with the screws you mentioned.
#99
Trans Am#5
C67 = HVAC Controls
RF Wheel well panel - 10037881
LF Wheel well panel - 10078275
91blackgta
I need the production broadcast code (upper left corner - two or three big letters) from your current PROM, as well as the service controller number (in box in upper right corner). If you don't have these numbers I can't look it up for you.
C67 = HVAC Controls
91blackgta
