Aftermarket 17" IROC rims from Performance Wheel Outlet
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
I want to get these 17" aftermarket Iroc rims from Performance Wheel Outlet but, I noticed that they only have the front wheels available with the 0mm offset. Does any other manufacturer make these rims with the factory offsets for both the front and rear wheels?
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
http://www.capitalwheels.com/newsite/index.html
they might
cant you use a front wheel on the rear anyhow it would stick out nicer.
they might
I'm going to mount the front wheels on the rear to see what they look like. If they don't fit inside the wheel well right I'm going to just order the 17" ROH Snypers.
I just received an email back from Performance Wheel Outlet and they said that they've found that running four front wheel offsets does not affect handling or performance in anyway and you could also rotate the wheels.
I'm still going to mount my front wheels on the back just to see what it looks like.
mustangman65_79
Aug 11, 2015 03:17 PM
