Rear Convertible Window Cancer
Old Apr 27, 2003 | 12:52 PM
'91_Z28_droptop's Avatar
How can I get rid of the cancer spreading across my rear window without ruining the plastic? You can see it on the bottom.
Old Apr 27, 2003 | 01:23 PM
Dan88IrocZ's Avatar
WOW that is the worst I've seen!!
Hmm....when my old top had some, I used the finest grit rubbing compound I could find...
Old Apr 28, 2003 | 12:01 AM
underdave's Avatar
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
mine isn't quite that bad, but i definitely understand your pain. so i'm looking for a solution too.
Old May 21, 2003 | 02:27 AM
89rdroc's Avatar
you know my window used to look worse then that, so i replaced it with a new one(the whole top) i dont know what you can use to take it off but keeping it from spreding is what you should try. the reason why the window turns yellow is because of UV rays from the sun. what i do is but a large towel over the window when my is car parked in the sun. its been working so far, just think of a way to keep it on with out the wind blowing it off. thats my own personal solution.
Old May 21, 2003 | 08:41 AM
Topless91RS's Avatar
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
My brother gave me this plastic window polish that he had from when he had his Wrangler, it works good. I will get the name off it and post it. Its a 2 step process I believe!
Old May 21, 2003 | 05:05 PM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
3m makes some. it depends on if the gray is on the surface of the plastic. i've also used some stuff in a white bottle with blue stickers. cant think of the name. quick search on the web came up with this...........http://www.properautocare.com/renplaswinpo.html
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
69 Six Pack
Oct 5, 2015 07:51 PM
