T-top Problem/Question
Old May 11, 2003 | 05:13 PM
91 Camaro Z28's Avatar
Ok, people, i'm not sure where this post should go so we'll try here first..
i've got a 91 Z28 with t-tops and i keep seeing the different storage "options"
Which one came with my car?
Where are they supposed to be stored/mounted at?
Did the 91s come like this picture? or some other way..
Attached Thumbnails T-top Problem/Question-222944_71_full.jpg
Old May 11, 2003 | 05:49 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
My 89 T-Tops are stored that way...
leather bag with straps....
Old May 11, 2003 | 06:06 PM
i need to know if something was changed in the 91 year(or possibly the 90-92 series)
I have the hooks that are in front of the rear taillights, but i dont see any provisions for the straps that are supposed to be behind the rear seats.. is it different in 91?
Old May 11, 2003 | 06:07 PM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I was under the impression that all thirdgens w/ T-Tops came with the bag and straps. I know there are a few here that made their own to fit in the trunk area. I could be wrong though. Mine has the leather GM bag with the straps as well.
Jeremy
Old May 11, 2003 | 06:40 PM
25THRSS's Avatar
My 92 rs has the bad with straps and everything exactly like pictures except I dont have the gm logo, it is just plain black leather.
Old May 11, 2003 | 06:59 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Transmission: 700R4's
Both my 84 and 86 have the bag w/straps. So does my friend's 92 Z28. Maybe someone removed hardware?
-Jeff
Old May 11, 2003 | 07:50 PM
BTS88IROC's Avatar
All 3 of my camaros have had t-tops, my 88's both have the bag and straps, my 86 SC however didn't have anything, maybe someone removed it??
You should have provisions for the other straps. You might have to pull up your rear carpet to find the holes. Its just 2 little brackets and then the straps hook to them.
Old May 11, 2003 | 09:12 PM
i have the "tabs" on the rear part of the car.. but the part thats behind the seats has nothing.. in the picture in the earlier post, it looks like the car has like a flap or something that covers the dip in the back of the car.. i dont have that at all..
does anyone with a 91Z28/T-tops have a picture of their setup? that would be most helpful
Old May 11, 2003 | 09:48 PM
MdFormula350's Avatar
well in that pic thats looks like a standard t-tops moutning with an optional hatch well cover, most likely the optional bose system with fold up panel.
Old May 11, 2003 | 10:27 PM
bigals87z28's Avatar
Car: Check The Sig
The only other thing i can think of to store your ttops is if you had some type of set up from a 4th gen. They have slots to slide there ttops in, and then there is a little thing to cover them. I have never seen that extention piece in the first pic. Probably just a speaker box.
Old May 11, 2003 | 11:08 PM
BTS88IROC's Avatar
That extension piece, is as mdformula said, its the optional hatch well cover, my car has that option on it.
Old May 18, 2003 | 04:47 PM
ttt.. anyone?
Old May 18, 2003 | 05:01 PM
BTS88IROC's Avatar
What are you looking for exactly?? I'm pretty sure the only option of storing the t-tops was with the t-top bag, what other 'options' have you seen??
Old May 18, 2003 | 05:27 PM
i need to know why my car doesnt have the tie-downs behind the rear seats like everyone else's car does. was it not available on the 91 Z28s? wheres a good place to get the tie downs if i'm supposed to have them?
Old May 18, 2003 | 05:33 PM
25THRSS's Avatar
I would bet the carpet has been replaced and they didn't put the tie downs back on. Just go to a junk yard or the dealership I think still has them. Is yours a 305 or 350?
Old May 18, 2003 | 06:18 PM
305
will there be holes where the tie-downs were secured to?
Old May 18, 2003 | 06:38 PM
BTS88IROC's Avatar
There will be holes, but you will never find them without lifting up the carpet and checking. When I replaced my carpet I left those 4 screws in and then laid the carpet on top of them and then found where they were and put a little X cut over the top of them with a razor blade and then pushed them through. I think I might have an extra set of the hold downs if you can't find them anywhere, let me know, I'll have to take a look though.
Also I think the option was avaliable on all years, I might be wrong though...
Old May 18, 2003 | 07:15 PM
ya, if you dont mind parting with the tie downs, it'll make the project a lot easier- you wouldnt happen to have an extra GM t-top bag would you? lemme know man
Old May 18, 2003 | 07:26 PM
BTS88IROC's Avatar
Actually I do have an extra t-top bag laying around also, however I believe it needs a new zipper. I had 2, but I cut one up when I made my t-top bag. I'll have to do some checking and get back with you.
Old May 18, 2003 | 07:27 PM
sounds good- a broken zipper is better than no bag at all.
how much would you want for the pair(bag/tie-downs)
jburroughs@comcast.net is my email so we can talk there
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
