TA wheels
Old Jun 16, 2003 | 06:15 PM
Packy's Avatar
TA wheels
I have a few quesitons.
1 What year rims are these?
2 Is there supposed to be a difference in look, front and rear rims?
3 How do I clean these up? Im thinking placing wheel on rear and spinning wheel while hitting it with fine to very very very super very fine paper
Old Jun 16, 2003 | 06:33 PM
devianb's Avatar
The GTA rims from 86 -87 were different than 88-92s. All GTAs sold now are the 88-92 style. I would show you the difference, but you have to look very closely close up. Basically the 88-92s have dimples at the ends of the spokes.
Yes the rears are suppossed to look different than the fronts. The deep dish in the front is deeper than the rear.
There was a 15" rim that looked like the one in that pic. And then there were aftermarket 16" ones that looked liked that one.
Its pretty hard to tell what rim you have there.
Old Jun 16, 2003 | 06:40 PM
Packy's Avatar
These 16s and all four are deep, and nope no dimples.
I did see an 88 with white wheels where the rear were not as deep. But i thought it was cause he had drums, i have 4 wheel disc
Old Jun 16, 2003 | 06:44 PM
devianb's Avatar
Since you say they are 16s, and are all the same, then its an aftermarket set.
Old Jun 16, 2003 | 06:46 PM
Packy's Avatar
Ok, Im cool with that.
Since the gold is shabby looking im prlly gonna shot them a diff color.
Any clue on how to clean the rust from the aluminum part
Old Jun 16, 2003 | 06:51 PM
devianb's Avatar
Honestly I have no idea.
Old Jun 16, 2003 | 06:54 PM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
steal wool
Old Jun 16, 2003 | 08:31 PM
nolanr0413's Avatar
Car: Trans am
get different rims , or have them powdercoated.
Old Jun 16, 2003 | 08:39 PM
Packy's Avatar
hehe i would get different rims, but i already got the RA 2 hood comin so money is gettin tight. Add ontop of the the head and flame arestors for my jet ski, im gonna be out some major chaching
Old Jun 17, 2003 | 10:57 PM
EDDIETA_ZZ3's Avatar
Car: Trans Am
Engine: ZZ3 HO
Transmission: 700R-4
They Look like Enkei 16X7 inch wheels produced in 1986.
I have a set on my car. If you decide to use them they will still be an upgrade from the 15X7 inch stockers since they are much lighter (less unsprung weight). The center section is cast aluminum welded on a forged outer rim. I repolished mine and painted them black. The tires that you will need for the wheels to look right are
Cooper cobra GTZ or Pep Boys futura tires in a size of P225/55/ZR16
Don't let the 225 size fool you as being too narrow. In fact the tread width is much wider than a 235/60R15 tire (15 inch rim tire). The reason is because the 225/55ZR16 is measured as a lower profile tire. Also, some known OEM size 245/50/16 tires have the same treadwidth as the 225's I have mentioned.
Also, don't let anyone talk you into putting a Comp TA 245 size tire on a 16X7 wheel because it will buldge.
Hope this helps
Old Jun 17, 2003 | 11:03 PM
Car: Trans Am
Engine: ZZ3 HO
Oh btw,
You'll be able to rotate your tires by yourself unlike the GTA rims
where you'll have to take the tire off the rim due the 16 mm offset the GTA rims have at the rear.
So actually you have some advantages with the Enkei wheels
Old Jun 23, 2003 | 03:52 PM
Packy's Avatar
well, I took some steel wool and alittle mix of compunds and nufinish, and some time. Followed by some alum buffing compound and polish compound.
Yeah they are Eneki, and i have the one to straighten out I hope it can be safed, I cant find these rims anywhere
Old Jun 23, 2003 | 03:53 PM
Packy's Avatar
ouch
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
