hood's here
Old Jun 20, 2003 | 10:38 AM
CamaroRS385hp's Avatar
Car: 1987 Iroc-Z28
Transmission: auto
hood's here
my hood's here! well actually the guy's like 2 minutes away, but i'm still excited! too bad i have a doctors appointment in like 20 minutes, i'll have to fit it this afternoon and then post some pics.....yay!:lala: :lala: :lala: :lala: :lala:
....uhh, sorry if that seemed kinda gay
Old Jun 20, 2003 | 11:53 AM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
Very nice, what type of hood did you purchase?
Old Jun 20, 2003 | 12:18 PM
Car: 1987 Iroc-Z28
Transmission: auto
Big Block :lala: :lala: :lala: :lala: :lala:
I'll post pics later today of the install....i need to get somebody else over here to help lift off the hunk of steel that is currently over my engine
Old Jun 20, 2003 | 12:51 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Congrats The steel hood is easy to take off by your self. Just put the car outside, then unbolt everything and sit on top of the motor push up on the center of the hood and then lunge it forward catapulting it away from the car. Or pick it up in that position and carry. Its not reall heavy just a large object to pick up. I used that technique 4 times that I've removed my hood and put it back on.
Old Jun 20, 2003 | 01:03 PM
nolanr0413's Avatar
Car: Trans am
are you going to cut the hole open in the front of the hood, i think it really needs to be opened up .
Old Jun 20, 2003 | 02:36 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
I agree. If you cut that space out and make a little custom black grill it would look awesome. Either way nice choice of hood.
Old Jun 20, 2003 | 03:27 PM
Car: 1987 Iroc-Z28
Transmission: auto
i had thought about it, but i don't trust myself to do it, and i don't feel like payin a shop to do it for me. if i end up not selling my car, i'll put it on my car and get it painted, and have the "cut-out-area-that-actually-isn't-cut-out" painted black, while the other parts of cowl are red...just to make the cowl parts stick out a little more
Old Jun 20, 2003 | 03:40 PM
Car: 1987 Iroc-Z28
Transmission: auto
well i dont know about photoshop, but here's my Windows Paint at it's best just to give you a kinda rough, ok extremely rough, idea of what it'd look like
Old Jun 20, 2003 | 03:41 PM
Car: 1987 Iroc-Z28
Transmission: auto
Old Jun 20, 2003 | 04:37 PM
FLYNLOW92rs's Avatar
Get that hole cut open, or at least paint it black, so it looks like something is open there.....
Old Jun 20, 2003 | 05:34 PM
Car: 1987 Iroc-Z28
Transmission: auto
yeah if i don't get it cut out, i'll def. get it painted black.....what kind of rubber seal could i use around the hole though? i could manage making my own screen.....but what would i use to seal it and how could i attach the rubber seal to the hood?
i just test fitted the hood a minute ago, but took it off again before i remembered to take some pics i need to drill the screw holes on the hood bracket (the oval shaped ones) a little bit longer, because the furthest up the hood gets is about 1/4 in. short from where it needs to be, so.......my dad was helpin me hold it up, but he's leavin so i gotta wait for a buddy to come over and help me, but it shouldn't be too much longer......also, what'd yall use to remove the tape and sticker goo? goo gone would prob. work but i don't have any.....what else would work?
Old Jun 20, 2003 | 06:44 PM
kerryismygirl89's Avatar
Car: 1989 Firebird
Engine: LB8 (2.8L V6)
Transmission: MD8 (Auto)
Not gay at all, Camaro. Nice to see someone excited!!! Good for you!!! :lala:
Old Jun 20, 2003 | 10:40 PM
yesfan2000's Avatar
Car: 1987 z28
You could probably use some WD-40 to take care of that adhesive from the tape.
dave
Old Jun 20, 2003 | 11:07 PM
Car: 1987 Iroc-Z28
Transmission: auto
took a while to get it to fit just right.....had to drill the oval screw holes 1/4 in. longer so the hood wouldn't be too short in the front, but overall an excellent fit. ASCD did a great job. all the bolts were in the perfect place, the only thing i'm still workin on is i gotta find a way to make the bracket that latches the hood down, come down a little farther. the bracket that unlatches when you pull the lever in the car (not the bracket that you manually unlatch reaching under the hood) doesn't go down far enough to latch, so i gotta buy a couple washers or something tommorow to get it down a little farther...here's the pic
Old Jun 20, 2003 | 11:31 PM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
was this what you were wanting for the hood?
Old Jun 20, 2003 | 11:37 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Camaro, how was the firment of the hood?
Also can you reverse the red and black on the hood? see how that looks?
Old Jun 20, 2003 | 11:40 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I think you should paint it red with the cowl part black (opposite of the way you have it in the pic) if you must do a two-tone deal. If not, all red and get the piece cut out.
Old Jun 20, 2003 | 11:53 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
im with MetalliCamaroRS on that one
Old Jun 21, 2003 | 12:01 AM
jgifford's Avatar
Car: 1986 Z28
Sorry, my color matching skills aren't the greatest but you get the idea...
Old Jun 21, 2003 | 12:15 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
i like the second one better, red with black...
Old Jun 21, 2003 | 12:42 AM
bubbakutz's Avatar
Engine: LG4
now the red grille looks off......black z one w/ red bowtie would look nice
Old Jun 21, 2003 | 01:46 AM
jgifford's Avatar
Car: 1986 Z28
I like this one...
I also went ahead and fixed your turn signals.
Old Jun 21, 2003 | 12:19 PM
Car: 1987 Iroc-Z28
Transmission: auto
looks great guys...i love that last one...do you think somebody could switch in the z28 grille w/ the red bowtie?
i didn't mention it before, but if i got the hood painted black, and the cowl painted red, i'd be getting the rest of the car painted black too. the red stripe on the cowl would continue up onto the roof and down the back deck.
could somebody take the time to do that too? make the hood like that first pic...black w/ a red cowl, but then make the rest of the car black too, cause unless i change my mind, that's how i'll want to get it painted...thanks
Old Jun 21, 2003 | 12:22 PM
Car: 1987 Iroc-Z28
Transmission: auto
do you mean how was the fitment of the hood, or how firm was the hood? it fits almost perfect...i needed to modify my hood brackets a little so the hood could slide up farther on them, and make the hood latch hang down a little longer, but that's it. it's a great fit.
as for how firm it is....uhh it's real sturdy....about 1/4 the weight of my old hood, but it's great quality....don't go with anybody but ASCD
Old Jun 21, 2003 | 01:00 PM
Do you go to Florida State, or do you just have their license plate?? I'm going to Florida State in the fall.........
Old Jun 21, 2003 | 03:04 PM
Car: 1987 Iroc-Z28
Transmission: auto
nah i go to valdosta state, but FSU's my team (football). i wouldn't have put that plate on, but the previous owner had on a Georgia plate (not a real license plate, it said like "Georgia on My Mind" or something and had a peach......I don't know what the hell they were thinking ), so when i took it off there were screw holes in the grille, so i had to cover it up w/ something
Old Jun 21, 2003 | 06:45 PM
jgifford's Avatar
Car: 1986 Z28
Here's One With The Z28 Grill
Old Jun 21, 2003 | 07:18 PM
jgifford's Avatar
Car: 1986 Z28
And Black...
Old Jun 21, 2003 | 07:53 PM
Car: 1987 Iroc-Z28
Transmission: auto
:hail: :hail: :hail: :hail: after looking at both of those, i'm FOR SURE going with my original plan and getting it black w/ red. damn that looks mean! one last request....could somebody put a pair of foglights on the black car pic? thanks alot!
Old Jun 21, 2003 | 08:05 PM
jgifford's Avatar
Car: 1986 Z28
...And with fog lights
Old Jun 21, 2003 | 08:13 PM
Car: 1987 Iroc-Z28
Transmission: auto
:hail: :hail: thanks so much!! i have photoshop 7.0 but no manual for it, so i haven't figured out anything yet...ya kinda got me leaning towards fixin up my exterior this summer and worrying bout the v-6 to v-8 swap later down the road.....i love that color combo!..thanks again
Old Jun 21, 2003 | 08:35 PM
jgifford's Avatar
Car: 1986 Z28
Something I would recommend is first the wheels. I think it would balance out better is they weren't red. Also, you may have noticed that I added clear turn signals and new parking lights. Other than that, I think the red interior would look great with the exterior colors.
Old Jun 21, 2003 | 08:40 PM
Old Jun 21, 2003 | 10:20 PM
Car: 1987 Iroc-Z28
Transmission: auto
yeah i had planned on a new front gfx (the current one is warped a little), z28 grille, new running lights and clear turn signals if i went ahead and got a paint job. the wheels will be switched too, but only if money allows after tha paint job. depending on how much i can get a paint job for, i may or may not get wheels this summer. i'll have roughly $2500 after the summer, so if i can get a paint job for under $1500 it should be alright....just all depends on when i'm gonna make up my mind on what to do. if i can find the time (and if i feel confident enough with it), i'll do all the prep work myself so all i'll pay for is the paint and an hour or two of labor
Old Jun 21, 2003 | 10:24 PM
Car: 92' RS
Engine: LO3
Yeah I meant how was the fitment. Heard of some problems with not following th fender lines
Old Jun 21, 2003 | 10:26 PM
Car: 1987 Iroc-Z28
Transmission: auto
got another question....i have silver emblems on the sides of my car (and red on the back, i don't know why they mixed it up), but i'm not sure if i wanna just leave them all off, or get red side emblems........it'd look pretty good, continuing the red/black theme, but it might be too much...here's a side pic just for reference, or if you want to photoshop it, be my guest. i'm takin off the front emblem for sure though
also, i'm undecided about whether or not i want the side moldings...and before you say it, yeah i'm getting bigger tires...these are only 235's
Old Jun 21, 2003 | 10:41 PM
Car: 1987 Iroc-Z28
Transmission: auto
nah it's pretty damn near perfect...i'll post some pics tommorow showing the fit better...the only problem i had was the hood not coming up far enough, but it was a quick fix to modify the hood brackets
Old Jun 21, 2003 | 11:21 PM
I had that problem as well....
I just put washers between the actual hood and the hood hinges on the side that was too close to the fenders, and it fixed the problem right away....
Old Jun 21, 2003 | 11:23 PM
I say get the red & black emblems....
And NO side molding, looks much cleaner without it, that's why i left it off.....
Old Jun 22, 2003 | 01:11 AM
Car: 1989 IROC-Z
Engine: 383 stroker
I think it'll look funny with one thick stripe on the roof and rear decklid. I say just paint the top of the cowl red, and the rest black.
Any engine mods planned (perhaps a swap) to back up the mean look?
Old Jun 22, 2003 | 08:51 AM
Car: 1987 Iroc-Z28
Transmission: auto
i'll have to do a little research on it before i get it painted, but i've seen a pic of a camaro with an SS hood, and they had the cowl painted, then a stripe down the roof and deck and it looked real good. and as for engine upgrades.....it's gonna have to be put off for a little while. i was debating this summer whether to spend my money on a v-8 swap, or go for appearance first. well i ended up ordering the hood, so i'm going with appearance. don't know yet if exhaust from a v-6 will hook up to a v-8, but if it will then an exhaust and full tune-up will be my only real mods this summer. then all the money i get after that will be saved up until i have enough for the swap
Old Jun 22, 2003 | 09:45 PM
  #42
yesfan2000's Avatar
Car: 1987 z28
If that hood was designed specifically for third generation f-bodies, it should be a prefect fit. You should have been able to just unbolt the old hood and bolt your new hood on and be set to go. Not including the insulation or anything that you need to transfer from the old hood. Unless, of course, different years third gens came with hoods that only fit those year cars. I thought all third generation hoods were interchangeable with all third generation cars.
dave
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
