Removing rust from part on trunk
Old Jul 20, 2003 | 09:12 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey I would like some input to get rid of the rust around the area in the pic. My thoughts are to raise the trunk, and tape around everything that could possible be covered in paint. Then use a dremel to remove the rust, and some acid if necessary.
Once all the rust is removed I plan to use primer in a spray can.
After the primer is dry, is it ok to spray the entire thing? Do I need to remove all of the paint?
Old Jul 20, 2003 | 09:25 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Why not just use sandpaper to remove the rust?
I don't quite understand what you're asking in the last question either?
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Firebird sweden
Aug 16, 2015 05:02 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 8, 2015 07:09 PM
