Functional hood louvers - May be a way..
Old Jul 24, 2003 | 06:36 AM
MX265
Guest
Posts: n/a
I was thinking about drilling/cutting (2) 4" holes in the hood where each louver goes. Then sealing the edges of bare metal with silicon and weather strip. Then I was going to cut small slots between each fin on the louvers with maybe a sawzall. Then just bolt the louvers back in place. Only thing I would have to do now is see if I could install maybe a screen or some type of mesh underneath the hood to block debris from coming in those holes. It would have to be made easy to remove and install for cleaning.
So what do ya'll think? Am I nuts?? Any input is appreciated.
Andy
Old Jul 24, 2003 | 07:32 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I've been thinking about something similar, using a custom bent sheet metal filter housing and a large rectangular K&N panel type filter. The problem I've been seeing is that there isn't much room between the radiator support and the hood when closed for such a setup. What did you have planned for that???
Old Jul 24, 2003 | 09:34 AM
bigals87z28's Avatar
Car: Check The Sig
made this on autocad.. lets see if it works...
Old Jul 24, 2003 | 10:06 AM
MX265
Guest
Posts: n/a
Hey, that's pretty cool!! Looks like it would be great for TPI. I have TBI with K&N Open air though. So I figure if I could get air in or around the open air area, this would hopefully help a little. Like Bnoon said though, trying to get some sort of screen or mesh under there may be the difficult part.
Old Jul 24, 2003 | 10:23 AM
Car: Check The Sig
for tbi and carb, you would have to go with some type of olds 4-4-2 air cleaner with the ducts that face up. also, you would have to drill holes for rain.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
