ATTN GRABOID/Crazy/Kandied - Wheel question
Old Aug 13, 2003 | 08:40 PM
johnyIROC's Avatar
What backspacing are you running on the rear wheels?
I am going with 17X10 rears... and I'm thinking about 5 3/4" backspacing.... I was originally going to go 5.5BS.... but the supplier only stocks 5 3/4". So that should still give me some extra lip in the back without clearance issues on the inside.
Any help would be appreciated.
Old Aug 13, 2003 | 10:37 PM
CrazyHawaiian's Avatar
Car: too many ...
I'm running a 9.5" wide rear wheel with 5.5 inch backspacing. I found out what everone with 17x9.5's was using and went with the same backspacing as them. I would check out what guys with 17x10 are using and use the same backspacing as them. Yes its possible.
Old Aug 13, 2003 | 10:55 PM
johnyIROC's Avatar
Thanx man... I've PM'ed a couple guys winth 17X10s... but no one has gotten back to me. Graboid is the only one I know for sure who's got 10"s out back... and his look like they tuck fine.
Old Aug 14, 2003 | 12:00 AM
Kandied91z's Avatar
i will have 18x10's in the rear for the new wheels but the backspacing is custom for the rim and i would hate to have something go wrong if you tried it. email me if you still want to know and i'll get the build specs for them. i can't imagine them being to much different from other wheels but who knows.
Old Aug 14, 2003 | 05:25 PM
Graboid's Avatar
backspace
i am not sure, but i guess the backspace on my rear rims is 5.75.
but i would not bet on it. All i know is that it doesn't look to bad...
Attached Thumbnails ATTN GRABOID/Crazy/Kandied - Wheel question-top4a.jpg
Old Aug 14, 2003 | 05:45 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
My 18x9.5" Z06 rims have a backspacing of 7.5" with a +56mm offset. So I used a spacer just under 2" to give approximately 5.5" of backspacing. The max backspacing on the rear is 5.85", so they fit like a glove. The max for the front is 5", however the 2" adapter in the front did the trick for mine (front). The tires on all four are 275/35 ZR-18's. Hope that was helpful.
Attached Thumbnails ATTN GRABOID/Crazy/Kandied - Wheel question-rim.gif
Old Aug 15, 2003 | 03:46 AM
Graboid's Avatar
hot damn!
that's one of the better looking camaro's i have seen in a long time. Nice detailing without overdoing it. Cool ride, man! Ilike the ss emblems more than the stripes.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
R3500
Aug 24, 2015 09:05 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
