how much paint?
Old Aug 26, 2003 | 01:04 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
how much paint?
i have a red 90 bird that is going to be painted by my friends father. However, he wants me to pick up all the supplies. My question is how many pints of paint would i need to get?
The car will be getting 4 coats of color then a clear.
Old Aug 26, 2003 | 09:01 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
ttt i know someone out there paints their own car.
Old Aug 27, 2003 | 08:01 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
when i painted mine, it took roughly 1.5-2 pints per coat. (pretty sure)
Old Aug 27, 2003 | 08:06 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
for a car, we normally just bought a gallon dupont black, that normally saw us through. don't forget reducer however, sand paper if he wants u to pick that up also, bondo, etc....painting does take a ton of equipment, beautiful thing about having someone w/ a business that ya own part of .
Old Aug 29, 2003 | 03:22 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I just finished total repaint. You really dont need 4 coats of color 3 will be more than enough ustally 2 is enough. However, 4 coats of clear would be advisable, particularly if you are going to wet sand when it is done.
This is based on PPG paint and reduction amounts. Color is reduced 2:1 and Clear is 4:1:1 so a gallon of reducer should do you fine. Now this all is based on using an HVLP Gun. If you use a regular gun you will need more paint due to the fact that less is going on the car and more in the air.
I used 2 quarts of color and 1 gallon of clear. I have clear left over a little over a quart, however, If you buy 3 quarts it will cost about just as much as a gallon.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
