Tire size question
Old Sep 22, 2003 | 04:17 PM
ator's Avatar
Car: 92 Firebird Formula
Transmission: 700 R4, 3.73 rear
Tire size question
I was wanting to know what is the largest tire size that can go on this rim, is it from my 92 Formula 350. Right now there are 245/50-16 all the way around, but I wanted to put a larger tire on the back (wider not taller)
Also, the lip on the front rims seems to be atleast an inch deeper than the rear? It was like this when I bought it and the guy I bought it from (he was the original owner) claims thats how it was new and how it's supposed to be. The rears are significantly cleaner on the inside and don't apear to have ever been on the front. My other question is, Is this correct? And if so, why?
Old Sep 22, 2003 | 04:35 PM
Murt TTA's Avatar
Car: 89 TTA
Engine: 3.8L turbo
Transmission: 200r4
The front and rear rims have different off sets, and shouldn't be rotated, that guy was correct.
As for tires, I run 255/50's on the back of my car. I think U can fit 275's on the rear without any problems... 245/50 are the stock size.
The rears might be cleaner because your front brakes do alot more work then the rears do when stopping. My front brakes always are significantly dustier then the rear.
~Murt
Old Sep 22, 2003 | 04:47 PM
ator's Avatar
Hey, thanks for the reply. When I said the rears were cleaner I was just trying to prove the original owners point that that is the way it should be.
So 275's huh? 275/50's I assume, I think I will pick up a pair since I can't rotate em anyway. The tires on now are new so that will give me an extra pair for the front as well.
Old Sep 22, 2003 | 05:30 PM
Spdfrk1990's Avatar
i never seen 275 on but wouldnt that be a stretch i was gonna get some 255's
Old Sep 22, 2003 | 06:23 PM
StealthElephant's Avatar
Car: 87' Iroc
I was told that running anything over 255-265 you'll get very uneven wear, the outside will not wear hardly at all, with the inside takeing all the abuse.
I wouldn't think 275/50, I would think 275/35 or something like that, because the 2nd number is aspect ratio in respect to the width, I could be wrong.
Old Sep 22, 2003 | 06:26 PM
Spdfrk1990's Avatar
i think u wanna stay with 50 series or it will throw off ur speedo with 16's
Old Sep 22, 2003 | 06:37 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
Wrong.
245/50/16 = 25.6" diameter
275/50/16 = 26.8" diameter
The closest size in 275 would be:
275/45/16 = 25.7" diameter
Except they don't make radials in this size, just DR's I think.
Old Sep 22, 2003 | 06:38 PM
Spdfrk1990's Avatar
i c so i wanna get 255's i stay with 50 series tho right
Old Sep 22, 2003 | 06:41 PM
Ya it will be close enough.
Old Sep 22, 2003 | 06:51 PM
Spdfrk1990's Avatar
alright thanx
Old Jun 6, 2012 | 05:27 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Re: Tire size question
looking to get 255/50/16 DR's, but you are saying that the 275/45/16 dr's are almost same diameter and will fit in wheel wells? and they are wider right? i have 16" gta rims.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
knight72
Aug 10, 2015 09:32 PM
