S-10 rims question
Car: 1987 Pontiac Trans Am GTA, 1992 Chevrolet Camaro RS
Engine: Custom 350, 3.1 V6
Transmission: 700R4, 700R4
S-10 rims question
Do rims from 93-03 S-10 rims bolt up to our cars without any spacers? I know they are a 5 lug pattern. I was thinking this would give us a lot more custom wheel choices since that bodystle of S-10 is really popular in the aftermarket. I saw '98 S-10 at the dragstrip last night with some nice chrome rims and made me wonder if those would bolt right up to my Trans Am. Also, anyone have any pictures of S-10 rims on a f-body?
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The bolt pattern is the same. The back spacing is a "hair" less on the s10, so they would stick out a tad more.
The problem is the center hub. the camaro center hub is more (bigger) then the one on the s10. Or atleast on a z it is, not sure on an rs.
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
i swap rims on my s-10 and 91rs all the time prolly at least 5 times a year just to change things up a bit they fit perfectally (on mine at least can't speak for everybody)
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
They have to be 2wd S-10 wheels I believe. 4wd S-10 wheels are a different offset. At least that is what I remember reading.
I too had a set of aftermarket S-10 wheels on my car for a while.
Wasn't too pretty,
Wasn't too pretty,
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
These are s-10's and they just popped rite on there
And yes I know they are the worst rims ever to be seen, But They are just there so It had something to roll on
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
just to clear this up...
82-97 s-series 2wd wheels will bolt right on...
98-present require the center hole to be opened up just a little
all the s-series 4x4 wheels require adapters just like 4th gen wheels...
later,
Chris
later,
Chris
Car: '89 IROC-Z Convertible & '91 RS
I have a set of S-10 X-treme rims on my '91 RS. They fit perfectly and they do give it a more custom look. I've never seen them on another Camaro around here.
Djmathis123
Sep 29, 2015 01:36 AM
