Decal removal
Car: 1989 RS Camaro
Engine: 305 POS
Decal removal
On my car I have a bunch of white lines that run pretty much the length of the car, you can kind of see them in my sig. and also there is like the trim that runs along with the lines. I want to remove everything that I talked about above, what would be the easier way? Thanks, if a better picture is needed you can just pm me.
3M sells 2 great products for that application. I'm not sure of their exact name tho, 1 is a sticker remover, the 2nd one is a glue remover. Works great! Don't do that when it's sunny outside, do it in a garage or under a tree or something.
I used a heat gun to take my pinstripes off "VERY CAREFULLY" or you will blister your paint, then wd40 or glue remover "auto paintsafe" then give the area a light cut & a polish, coz most likley there will be a slight colour change as the paint under the stickers will not be sun affected.
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
heat gun works just enough for the plastic to get soft then use a goof off or saomething like that to get the glue off. i have used easy off oven cleaner to remove panted on stipes and lettering off my old service truck, just have to work kinda quick with the stuff so it don;t eat the paint that you want to stay.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
well i found the perfect way to remove the pin stripes, use a pressure washer, it will get the decal off, and the adhesive will look so smooth that it looks like the paint, then you use some kinda adhesive remover to get rid of the glue, then your all set.
Originally posted by CrazedCamaro
thanks for the input on the decals, now any input about the trim?
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
If you have lots of decals/pin stripes to remove, have access to an autobody store they sell what we always called an eraser that you can chuck up in a drill or diegrinder. It is a round thick disc that looks/feels like an eraser you used in school. This is a effiecent and safe way to remove any decals/stickers that will not harm paint/clear coat, etc... If I remember right these can be had for around $20 or less and seriously cut down elbow grease/time when removing. I used to letter/decal semi's and trailers when I ran our trucking shop and this saved me tons of time since most of the owner operators would come in with the former employers decals all over the rig and I'd have to remove it all before appling all our companies logos. Just be sure if you use it around stripes you dont want to remove you use a steady hand-I acidentally removed a 3" chunk of pin stripe of my work truck when I removing the dealers sticker on the tailgate. Defienately a must have in the tool box and they last quite a long time with frequent use, any gummed up adhesive left over we'd just lightly rub with a rag/old shirt with paint thinner/laquer thinner/WD-40/bug &tar remover, etc...
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
i just took my pinstripes today i used VERY carefully a razor to take it off only do this if u got a steady hand an dthen with alchol or water grab steel woll an dscrub at it not too hard it works like a charm as well but take a while
Ahhh I'd never do that, happy you got good results.
1 slip with a blade and your up for a paint job.
I must admit the Alcol or alcohol idea got my attention , lol, coz I'm always up for a drink when I'm workin on the car
, Hope ya polished it after using the steel wool
, Hope ya polished it after using the steel wool Thread
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
