always wondered 1 piece vs 2 piece vs 3 piece wheels
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Why the heck are three piece wheels so much more expensive then two piece wheels and two piece wheels so much more expensive then one piece wheels. What makes the multi-piece rims so much better?
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
the reason that the 3 piece is more expensive is because it takes longer for the rim to be made
usually (and take this as usually) the 3 piece rim is strictly for race ready cars. because they are the lightest rim avail,
iroc2nv
iroc2nv
Car: 87 Formula 350
Engine: LS1 in Progress
Axle/Gears: 3.70 9 bolt
also being multipieced allows for a part of a wheel that has been damaged to be replaced w/o replacing the entire wheel...a plus if you ask me.
Axle/Gears: 3.45
as far as i know i dont think that they go bad zepher, all i can really see happening is the same thing that would happen to a regular wheel, just the oxidization of the wheel or peeling.. not sure about the seals being broken..
iroc2nv
iroc2nv
i'm thankful for having a 2 piece after i bent a barrel....no fun indeed. i guess the 4 1/4" lip is a bit much huh?
:lala:
definate advantages though with weight and strenght being the two highest up there. 3 piece has an added advantage using lighter materials in other areas as well as the ability to change the face of the rim down the road if you ever wanted too.
:lala:
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
NinjaNife
Aug 23, 2015 11:49 AM
