Polishing question
Polishing question
OK, couldn't find this anywhere.
How many buffing wheels (BW) do I need to buy?
Obviously each compound needs to be a dedicated BW, but will one BW do all 4 rims? (per compound)
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Yea just one per compound should do, I'm going through the process myself, so if you have any obscuer questions pm me, I had a little trouble getting a few answered on the boards.
Car: 1989 Firebird
Engine: 5.7 LS1
If you are using just one per wheel you will want a buff rake where you can knock the old off the wheel. especially if you use the smoothing kits with the 80/220/320 grinding compounds, the tripoli and white rouge pretty much leaves the bw when you are using it.
gixxer92
Sep 1, 2015 04:32 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
kah992
Aug 19, 2015 02:55 PM
