Polishing stock aluminum wheels...
Car: 1986 IROC Z
It seems there is some kind of coating over the aluminum on my stock IROC wheels. Is there a way to remove this coating so the metal can be polished?
Thanks!
Thanks!
1 Post
Car: 85 iroc with 92 ground effects
Engine: 355 11.1 world product heads
Transmission: t56
Axle/Gears: 3.54 dana 44
Re: Polishing stock aluminum wheels...
Factory wheels have clear coat. I used paint stripper to remove mine. There is a few threads on here about members polishing wheels. I did mine and it takes 5-6 hours a wheel to make them nice.
My clear was peeling. I sanded it off by hand and then polished. As racerkilla said, several hours per wheel. It was totally worth it though. The polish looks awesome.
...I go over them once a year with Mother's Billet polish. Takes about 15 mins per wheel.
Sometimes a steel wool pad, SOS or Brillo, will get old crusty clear off the wheels. Takes some elbow grease but works pretty quick.
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
So, you don't re-clear after stripping? I want to refresh my TA wheels. The painted portion (center) is in good condition but the outer rings are CC'd aluminum that are dull and scratched. Just polishing doesn't get them back to where I want them.
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Thanks for the advice. I will probably strip and reapply clear coat over this winter. The aluminum on mine is more of a satin finish than yours which, by the way, look amazing.
Car: '85 Z28
Axle/Gears: 3.23 posi
Those wheels of yours with the thick outer rim can look the best of any polished third gen wheels I've seen. I wouldn't recommend putting clear coat back on. Its too easy to keep them up with minor TLC and never deal with chemically or manually stripping them again. Good luck.
1 Post
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
And if you haven't found it....
https://www.thirdgen.org/wheels
Engine: LB9 5.0 TPI
Transmission: 5 SPD
I was planning to avoid using the chemical remover on the remaining clear coat. I thought I could just wet sand it without jeopardizing the painted portion (which is in remarkably good shape). Then, mask the tire and center portion of the wheel and apply clear coat. Do you think I should forget this path and do the chemical strip with sufficient care to keep it off of the tire and painted portions of the wheel?
Car: '85 Z28
Another word on polished aluminum to think about is that when it becomes so smooth and glass-like it becomes resistant to minor oxidation. Any that does is easily re-polished. If you clear coat, any nick in the clear coat that will occur over time will let the moisture underneath and then watch the clear coat begin to peel away and you get to do it all again.
I just finished this process last weekend with the wheels on my 89. I removed the tires, brushed on the stripper, & used a small artist brush at the edges. It takes time & you need to be careful at the edges where it meets the painted centers. I stripped them, sanded them in 320 to get out the blemishes, followed in progression with wet 600, 800, 1000, 1500, then 2000. I had the luxury of spinning them on a brake lathe, so it was easier to hold the paper & spray them with water. I honestly spent 3-4 hours per wheel including re-mounting & balancing the tires. The pictures below make it look simple, but it takes some time & patience to do four wheels. The wheels were in really good shape before, just the typical clear problems most of these wheels have.
Engine: LB9 5.0 TPI
Transmission: 5 SPD
OUTSTANDING JOB! That is the result I am looking for F-Body Fan, they are beautiful. I hope I can come close to what you have achieved. Sounds like you left them bare with no clear coat. Am I right?
Remember that rattle can clear coat might not adhere well to polished surface. I suggest that you clear powdercoat them instead.
The way I look at it, my older cars sit in storage most of the time, & when they come out its usually pretty nice outside. So, a polished wheel should hold up for years before it needs a rub down with some polish again. If they were exposed to all the elements like most of our cars once were, then they won't last too long I suppose.
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Good point. I never thought about adhesion problems. I have done spot work with paint and clear coat that I have been really pleased with but the paint gave the clear a good base to grab onto.
You have swayed me to just polish and stop. I only drive the car about 3-5K per year now and they should be fairly easy to bring back their polished condition every few years.
Street Lethal
04-30-2019 12:14 PM
ambainb
04-25-2016 09:21 PM
kah992
08-19-2015 02:55 PM
