Tire Size Opinions
Old Mar 4, 2004 | 04:51 PM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
Tire Size Opinions
I just recieved my ZR1 rims that are 17x9.5 and I am thinking of puting 245/45/17 on all 4 rims. Would this be a good size tire for these rims. I have heard of people putting 275/45/17 on the rear but not sure. I know this has been talked about a lot before but I would like to hear others opinions on this. Pics of these tires would be a big help.
Old Mar 4, 2004 | 05:06 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I've been researching 17's this week because I just bought a new set of wheels too. Here is what I found: 245/45's are meant to go on a 7.5" - 9.0" wheel. 275/40's are for a 9 - 11 inch wide wheel. I'd go with the 275's if I were you.
Old Mar 4, 2004 | 05:08 PM
Gambit69's Avatar
so 275/40's all the way around?
Old Mar 4, 2004 | 05:10 PM
GarageToys's Avatar
While we are at it, I'm going to hijack your thread...
I bought a pair of 17x7 wheels and a pair of 17x8's. According to everything I've found, the largest tires I can put on these are 225/45's on the front and 245/45's on the rear. Anyone else have alternate recommendations?
Before you criticize my choice of 7" front wheels, let's just say that these wheels might not be for a thirdgen. shhhhh!
Gambit69-- yes, all the way around (assuming the tires will clear everything) I was going based on the wheel width, but they can't be so wide that they rub. I believe others are running that tire size on 17's on a thirdgen.
Old Mar 4, 2004 | 05:23 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
I had 235's on my 15x7's, and on a differant set i had 245's on a 15x7, my truck had 265's on 16x7's
Old Mar 4, 2004 | 07:17 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
285/40/17 BFG comp t/a's on 17x9.5 Zr1's :]
Old Mar 4, 2004 | 08:24 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You are going to want to run a 275/40 for the 17x9.5. I have that on my rear wheels and a 245/45 up front. I can get away with the 245 up front because the wheels are only 17x9. If they were a half inch wider like yours I would go bigger. A 245 tire is really meant for an 8" wide wheel.
Pics can be seen in my sig.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
knight72
Aug 10, 2015 09:32 PM
