Cragar Clearance...I need to know SOON!
Old Mar 15, 2004 | 12:28 PM
SweetRide45's Avatar
I was ordering the Baer Claw 13" and 12" Rear systems, and the guy wouldn't go through w/ the order b/c I said I wasn't 100% sure it would clear the 17x8" Cragar SS'. Has anyone verified this? I can't use the template, b/c I don't have the rims, and I can't go anywhere to see if they'd fit. Some people say no problem...others say NO...
Anyone have personal experience w/ it or know off hand? I need to order these brakes b/c they take the longest to ship...
Thanks!
Old Mar 15, 2004 | 12:31 PM
Oh, and these are the Classic wheels, not the Alloy ones.
Old Mar 15, 2004 | 01:48 PM
Does anyone have a pretty straight forward answer on this one? I'm sure SOMEONE has to be running those rims...
Old Mar 15, 2004 | 05:09 PM
So, no one is familiar w/ those rims??
Old Mar 15, 2004 | 06:03 PM
Genesis98's Avatar
Car: 88 Camaro SC
Engine: 2.8 ->305->350
How big are the baer brakes compared to C5 brakes? Those are 17" crager's in that picture, C5's are 12.75"'s ... .don't know how much .25 of and inch would change things.
http://82lt1.cz28.com/brakes/brakes.html
Old Mar 15, 2004 | 08:53 PM
Are the calipers bigger than the Baer system? I'd like to see a picture of the rim from behind to actually see how much clearance there is.
Any more info from anyone? It would really help me out. I'd like to order these asap.
Thanks a lot!!
Old Mar 15, 2004 | 08:58 PM
Genesis98's Avatar
Car: 88 Camaro SC
I'm no expert in this section but I'm pretty sure baer just uses factory GM parts slaps they're sticker on it and jacks up the price.
I know LS1 and C5 calipers are identical so would assume that is what those calipers are.. but then again don't take my word on that you should look into it though.
Old Mar 15, 2004 | 11:22 PM
Thanks for the reply. Can anyone verify that Baer and the C5 Calipers are the same, and w/ the extra .25" of Rotor, it would clear the rim?
Thanks!
Old Mar 15, 2004 | 11:25 PM
Genesis98's Avatar
Car: 88 Camaro SC
This may provide some information
https://www.thirdgen.org/techbb2/sho...hreadid=183169
Old Mar 16, 2004 | 09:22 AM
Originally posted by Machinist
It measures right at 15 1/2" ID. It's a STOCK 87 IROC wheel.
Originally posted by Justins86bird
My 17" Firehawk wheel's ID is less then that...It has a step in. Can't fit Baer 13" brakes either. It measures slightly over 15". I need to check to see if my LS1 rears will even fit.
Originally posted by Ebmiller88
SO, they'll fit but you'll have to get the right tire combo to work. I doubt a 255 tire will fit without rubbing issues. A 245 tire may rub on the '91-91 cars with the aero effects, but the earlier cars shouldn't have any problems.
Whew! What a post. Thanks though!
It seems that they were all talking about the stock rims. 16" IROC'S have the largest Inside Dia. from what I gathered. Justin's 17" Firehawks were even smaller than that! I think what was said was that the C5, LS1, and Baer kit all used the same size calipers, correct? From the other link, w/ that being said, it looks CLOSE w/ 12.75" rotors, but I'd like to see the actual clearance from behind, or have someone post who knows for sure, or knows the Inside Diameter of them.
Any idea's?
Old Mar 16, 2004 | 01:18 PM
Nobody
Old Mar 17, 2004 | 09:59 AM
Well, I'm about to give up on these boards regarding this topic. If anyone else has anything to add...please do so.
Thanks!
Old Mar 17, 2004 | 10:26 AM
fstgen3's Avatar
Car: 83 Z-28
Transmission: TH-350
I have a set of 15x8 Cragar S/S's on my car with stock brake components and no backspacing and they fit fine.. dont know if the bigger rims will make a diff or not
Old Mar 17, 2004 | 01:52 PM
I just need to know what you need to clear the 13" setup...what's the diameter clearance that you need...then I need to know what the 17x8 Cragar S/S' have for their inside diameter. I THINK they should fit, but I just want to double check.
Old Mar 17, 2004 | 04:30 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Originally posted by SweetRide45
Well, I'm about to give up on these boards regarding this topic...
To get the answer you're looking for, someone on the boards would have to:
1. Be running the exact wheel in the exact size as yours
2. Be running the exact same Baer brake setup
3. Be on the board in the last couple of days and notice your post
Not likely. Why don't you call Cragar and check the dimensions? You say that the Baer brakes will have the longest lead-time, but don't hold your breath waiting for the Cragars either. I ordered a set of the 17" Forged S/S wheels and they said it would be 6-8 weeks!
Old Mar 17, 2004 | 05:18 PM
Damn, alright...I'll have to go get ordering on everything then. I can't find a number for Cragar on their website. I e-mail'd them a LOOONG time ago, still no reply....I'll try and get some info
Thanks a lot guys!!
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Adams87Camaro
Jul 24, 2001 01:25 AM
CDnAP48
Jun 30, 2001 06:50 PM
Harley61
Nov 30, 2000 12:53 PM
