rim offset w/ 18" rims
Old Mar 18, 2004 | 05:27 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
hy, i have found a guy w/ some realy nice rims. I'm not telling you guys what they are off of, but i wanan know if they will fit a third gen's wheel wells w/ the right spacers.
There are 2 - 18" x 9" (+26mm, 6.11" backspace) front, and 2 - 18x10.5 (+27mm, 6.9" backspace) rear. They are 5-lug (5 on 4.5).
i have a 4th gen rear end in my iroc, so let me know. thanks.
Old Mar 18, 2004 | 09:55 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
Re: rim offset w/ 18" rims
I think that just ruined it for ya. Sorry. You need to convert from a 5x4.5 pattern to a 5x4.75 one and I don't think you will be able to without the wheels sticking out past the fender in the rear.
Old Mar 19, 2004 | 05:10 PM
Engine: peanut LB9
oh damn, i didn't even realized aboiut the bolt pattern. thanks.
Old Mar 19, 2004 | 06:03 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
If you really wanted to run those (ford) wheels you could get your rear axles drilled also for a 4.5" bolt circle and move the studs, this would also require new rotors or drilling yours, or a 2 pc dual drilled rear rotor, then adapters up front to change the offset and bolt pattern.
Old Mar 19, 2004 | 11:11 PM
DURTYBIRD's Avatar
No problem...just glad to help out.
Old Mar 19, 2004 | 11:19 PM
Engine: peanut LB9
to much work to put stang rims onm y car, tought they would loo good, i might just gat a set of boyd's w/ no finsih and have them anodized.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
rb85TA
26
Sep 14, 2015 10:29 PM
