looking for H4 conversion set-up
Old Mar 19, 2004 | 06:33 PM
tataconka's Avatar
Car: 1992 z28
Engine: 5.7
Transmission: auto
I am trying to find the H4 conversion setup, does anyone have a site that i might find them at. I like the look and will take as many sites as i can get..Thanks
Old Mar 21, 2004 | 11:46 AM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
i hate to say it to yah but, do a search..... here and at say google or whereever.
some companys that make em are Bosch and eurolite and apc
mine are bosch and i like em.
Plan on the harness upgrade that requires a relay install (in tech section).
I dont have any links for yah tho sorry
Old Mar 21, 2004 | 12:44 PM
PontiacRacing's Avatar
Car: 1987 Pontiac Trans Am GTA, 1992 Chevrolet Camaro RS
Engine: Custom 350, 3.1 V6
Transmission: 700R4, 700R4
I got some of the Pilot brand enclosures from Autozone. I've only done the low beams, but it really improves the look of the car. Both from the inside and outside. I'm currently saving money to do the high beams and order a wiring harness from Pep Boys. I put some blue tinted H4 bulbs in.
Old Mar 21, 2004 | 12:46 PM
crawlin 25th's Avatar
Car: 92 z28
Engine: carb'd small block
Transmission: th400
Axle/Gears: 10+2 bolt
www.lightlens.com has them...check them out...
Old Mar 21, 2004 | 08:40 PM
tataconka's Avatar
Car: 1992 z28
Engine: 5.7
Transmission: auto
They have the lights for ever year but the third gen cars, the only lights that thay have are the side markers.
Old Mar 22, 2004 | 01:47 AM
Car: 92 z28
Transmission: th400
if u are talking to me they do have them there...thats where i ordered mine from ...
Old Mar 22, 2004 | 04:07 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
No need to buy any harness. Just make the appropiate wire location swaps
https://www.thirdgen.org/newdesign/t...es/connect.gif
use a small pin or screw driver to release the wire securing tabs and bend them back out before you re install the wires in the new location. I did mine and they work perfect and have been for a while now.
Old Mar 22, 2004 | 04:10 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
http://lightlens.net/headlights.htm
Old Mar 22, 2004 | 06:47 PM
Car: '81 Trans Am
Engine: 6.6L
yes your half right....with my bosch kit these connector adaptors were already included in the kit for free with the bulbs and everything......
But the reason why you need a harness is to wire up a relay witch you need!!! No one says he had to buy a harness but makeing your own with the relay in it is pretty easy and makes things faster in the long run. With out a relay your headlights will cut out after they get hot or sometimes flash on and off.
Old Mar 22, 2004 | 09:37 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Hmmmm. I never knew that but Ill wait til I see the problem first. Havent had any yet and my headlights are running pretty much 75% of the time. Thanks for the info.
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
