Another 91-92 Camaro GFX swap on IROC...
Old Mar 28, 2004 | 06:19 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I started my 91-92 GFX swap on my IROC-Z today. I noticed a few fitment differences obviously...
First thing, the rear 1/4 gfx and bumper as significantly more "flared" out than the 85-90 ones. I am really glad I got the 1/4's too now.
The rear bumper was a simple remove and replace deal. A few nuts and some clips and voila, bumper off! My original bumper made the tail pipe stick out about 1" from the rear and with the new bumper it actually it tucked under it about 1/2".
As for the rockers and door GFX, easy removal. I almost forgot about the 2 screws behind the Z28 emblems...
Anyhoo, installation HOPEFULLY will go smoothly as I will have to drill holes to fit all the side peices on.
Overall, I'm really excited! BTW: I found out what was rattling around in my door - GLASS! Tons of broken peices all over inside the door.
Anyway, later.
Old Mar 28, 2004 | 09:54 PM
Shaneo's Avatar
Car: 87 IROC (looks like 91-92 Z28 tho huh?)
Engine: 355
hmmmmm.........
an 87 iroc converting over to 91-92 style Z28 gfx. sounds vaguely familiar
I hope you enjoy it. I sure like mine!
Old Mar 28, 2004 | 09:57 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
lets get some pics
Old Mar 29, 2004 | 03:23 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
how did u get the front part of the door GFX on??? my 86 had 2 screws that went into the 2 holes.. when i put the 91 z28 gfx on, they didnt have those holes and when i made my own holes, they still didnt fit.
Old Mar 29, 2004 | 06:25 AM
CrazyHawaiian's Avatar
Car: too many ...
I've done it to my 89 RS, and it looks like I'm gonna be doing it to my 89 IROC pretty soon here too. As for the sideskirts, you might have drilled the holes wrong. When I took the pre 91-92 sideskirts off my 89 RS, I had the same deal, two screws under where the RS decal was. Removed em and drilled new holes for the new sideskirts. Slapped em on, and attached the brackets from the inside (by removing portion of the front fenderwell) and the fronts were on. For the rear, I had to use a saw to cut some parts of metal off the body near the rear portion fo the sideskirts (right behind the door). Just didnt fit right untill I cut some of that metal away. I think the 91-92 pieces look better since they hang a bit lower. But dont worry guys, I always retain the proper badges (RS, IROC-Z, Z28).
Old Mar 29, 2004 | 06:27 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
There is a bracket instead on the 91/92 setup that you just need to drill for and put a pair of cut-nuts on. Hope this helps!
Old Mar 29, 2004 | 12:38 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I went out thru the garage this morning 4 work and d-amn the IROC looks naked w/o GFX!
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
LittleFranks
Aug 20, 2015 03:55 PM
reiderz iroc
Aug 13, 2015 04:57 PM
fonzie85
Aug 13, 2015 11:50 AM
