exhaust idea, will be done eventually
Old Apr 12, 2004 | 01:57 PM
  #51
84Camaro305's Avatar
Car: 1989 Pontiac Firebird
Engine: 305 TBI
I thought it needed a little more space around the tip...
Old Apr 12, 2004 | 01:59 PM
  #52
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
the thing is, look in the pics i posted above the gas tank is right there, there is no way to do it like that.
Old Apr 12, 2004 | 02:01 PM
  #53
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
just noticed in the second pic you can see the nice exhasut tip for the Dodge Ram We got. My step-dad put a Gibson Cat Back on it. It sounds relaly tuff too.
Old Apr 12, 2004 | 02:22 PM
  #54
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Are you talking about the picture 84Camaro edited ?
  #55
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
woops nevermind, i compressed those jpgs with a plugin you all dong have, gotta fix it
Old Apr 12, 2004 | 02:26 PM
  #56
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ok check above nwo there should be 4 huge pics up there
Old Apr 12, 2004 | 02:32 PM
  #57
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
84Camaro305 THANK YOU!!!!!!!!!! thats looks absolutly incredible and it will be done as soon as my classes end for this semester. thank you for that photoshop its stunning!!!! :hail: :hail: :hail:
Old Apr 12, 2004 | 02:34 PM
  #58
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
d00d look above at the pics i posted. Your gonan havea very hard time doing that unless you wanna knotch the bumper, or gonna have to a make a lot of bends to make it come out there.
Old Apr 12, 2004 | 02:41 PM
  #59
deadbird's Avatar
Engine: TPI 305/ v6
Notching the bumper would be the only requirement. Depending on how much of a notch you want, you may have to cut into the impact bar as well.
Old Apr 12, 2004 | 02:43 PM
  #60
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well have fun doing it.
Old Apr 12, 2004 | 02:44 PM
  #61
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well for one you have a firebird and i have a camaro and the camaro bumper hangs down more than the firebird one does so it would give more access, and for two YES you would have to use some extreme bends like i had previously stated but thats ok because it can be done.....d00d....
Old Apr 12, 2004 | 02:48 PM
  #62
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Umm, that is NOT the gas tank.
Old Apr 12, 2004 | 02:49 PM
  #63
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well its the well, so what. IT still it not supposed to be notched. THe well acts as a buffer when thatpart of the car is hit. Once stregth is sacrfied its not good anymore.
Old Apr 12, 2004 | 03:03 PM
  #64
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Well, the well is totally different from the gas tank, last time I checked. I would not want to fill my well up with gas anyways, or attempt to put my groceries in the gas tank, I dunno about you.
You ARE kidding about the buffer/"stregth is sacrfied" thing, right?
Old Apr 12, 2004 | 03:13 PM
  #65
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
nah the well actually serves as a purpose. Its a buffer so when you are rear ended you dont suddenly blow up the gas tank. Its there to allow maybe a foot of imact before the gas tank is hurt. Helps most of the time.
Old Apr 12, 2004 | 03:32 PM
  #66
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Maybe I'm the only one that down right HATES that look. I like it on a T/A but NOT on a Camaro. Maybe if you used the same rectangle tips but damn, the quad round ones look FUGLY to me.
Old Apr 12, 2004 | 03:33 PM
  #67
firebird89355's Avatar
Car: 1989 pontiac firebird formula
Engine: Currently building a 355
exactly
what im planning on doing to my car see
Old Apr 12, 2004 | 03:40 PM
  #68
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
ya those tips arent happening on an iroc. Im thinking when i do it to my car it will be 2 single tips, no idea on shape but round wouldnt look right, but i think a slight notch is key because otherwise the tips just sit too low and dont look right
Old Apr 12, 2004 | 04:01 PM
  #69
Engine: 305 TBI
I must leave for work soon, so I didn't put much effort in lining the tips up and getting them to blend as well as I could have. This is about the look you'd get with a camaro...
Old Apr 12, 2004 | 09:36 PM
  #70
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
wow....thats all i needed 84. thank you i really appreciate it and i think it looks awesome!!! im not a fan of the dual tips either however i think the lt1 tips looks awesome when the bumper is just notched a little bit.
Jake_92RS
Jan 28, 2020 10:37 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Cameeeero
Sep 18, 2015 04:00 PM
mustangman65_79
Aug 7, 2015 09:55 PM
