Can I polish this wheel ??
Old Apr 17, 2004 | 05:18 AM
joekickass's Avatar
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
Hi, I just bought another set of wheel, it is BMW M5 copy, 18's , 8.5J, 15mm offset, I would like to take my AC copy wheel off, but now I am think to polish them before put them on, those rim are painted in silver now, can I polish them ??
Old Apr 17, 2004 | 05:44 AM
JimmyG-91Z's Avatar
With enough time and effort you can polish any metal. My guess is that the M5 copies you have are aluminum which is the same metal as the Irocs/Z28's/Formulas/GTA rims that we all polish.
So to answer your question in a word .... YES
Old Apr 18, 2004 | 06:28 AM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
Hello,
where are you getting that wheel from??
just curious, because i really like BMW wheels pretty much all of them look awesome. i always wondered if they would fit a third gen
Old Apr 18, 2004 | 10:40 AM
joekickass's Avatar
Engine: 2.8
Transmission: auto
hi stevver84Z
There are many BMW in Taiwan and there are many choice for the rim, it is not hard to fine used even in 18's, they are kind of fit, the PCD is little different (120mm VS 120.65mm), the offset of 5/7 series is very close to third gen, after some custom work, they fit, check my car, those BMW rim do looks great, especially those import one like BBS...etc.
Old Apr 18, 2004 | 11:07 AM
stevver84Z's Avatar
yes, i saw your car on your Car Domain website, i like it a lot!! did you have to use spacers for those wheels??
Old Apr 18, 2004 | 11:08 AM
stevver84Z's Avatar
Oh yeah i also meant to ask if you know if 3 series wheels would fit?
Old Apr 18, 2004 | 11:37 AM
joekickass's Avatar
Engine: 2.8
Transmission: auto
thank you, there are still alot of work to do.....
Both my BMW rim are 18's, 8.5J, 15MM offset, the 5/7 serice rim need less modification due to the offset, the 5/7 one is about 15mm, 3 serice rim is about 35mm or more, you will need adapter.....or the wheel will go inside...
I fine a formula to calculate the spacer I need for different wheel, with this rim, I need 3mm spacer in the front, actully, the most important thing is custom a center rim, I don't how the express it in English, there are the pics, put the center rim between the wheel and bolt, that will make the wheel stay close to the bolt, or there will be alot of palys in driving....feel free to ask me for theBMW rim if I didn't explain it well..
Attached Thumbnails Can I polish this wheel ??-resize-q-s-b
Old Apr 18, 2004 | 11:39 AM
joekickass's Avatar
Engine: 2.8
Transmission: auto
this is the bolt in the front, the rear one looks different but the size of the center rim is the same.
Old Apr 18, 2004 | 11:42 AM
joekickass's Avatar
Engine: 2.8
Transmission: auto
this is the other side of the wheel, the center rim can be put on the wheel or the bolt first, in the end, they will stay together......
Old Apr 18, 2004 | 01:53 PM
stevver84Z's Avatar
That bushing keeps the inner wheel closer to the hub?? or is that used as the spacer?
Old Apr 18, 2004 | 02:31 PM
joekickass's Avatar
Engine: 2.8
Transmission: auto
yes, the bushing keeps the wheel close to the hub when spinning, it is different to the spacer.
Hotrodboba400
Dec 10, 2019 07:07 PM
Breazlan
Sep 25, 2015 11:20 AM
scottmoyer
Sep 7, 2015 07:06 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
