TA Tailight help!
Old Sep 11, 2000 | 10:28 PM
B L A D E's Avatar
TA Tailight help!
The grids are seperating from the clear sheild...how can I fix this? Also, the sheild is dull...what should I use to polish them?? To fix the grids...is it possible to remove them from the sheild to re-set them? I need to do this...help.
Old Sep 12, 2000 | 01:37 PM
B L A D E's Avatar
Please help!
Old Sep 12, 2000 | 06:37 PM
Dirk's Avatar
TGO Founder/Former Owner
Car: 1992 GTA
Blade,
I have a spare set of TA tail lights sitting at home. I'll check them out and see if they can be disassembled. I think they can be. I remember seeing a parts list on the internet that showed each individual part of the tail light, as if it could be removed.
I am not sure about getting the grids attached to the clear shield again... I'll see if the ones at home are glued on, cuz I think they are doing the same thing.
Use some good plastic scratch remover and plastic polish to polish the shield up. I think there is another thread here where people talked about what type to use
Old Sep 12, 2000 | 07:48 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Dirk, what year tail lights do you have just sitting? I am looking for a good set of 85-90 T/A tail lights, the ones that look like blackouts.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Old Sep 19, 2000 | 01:00 AM
Dirk's Avatar
Car: 1992 GTA
Blade,
Good and bad news... the good news is that that tail lights DO separate so that you can adjust the plastic pieces inside of them. Take the tail light out of the car. On the bottom, there are 2 metal clips. Pull those off. On the top, there are 2 plastic pins. Pull those out. After doing that, you can seperate the front and rear sections and clean out the reflector and re-set your plastic thingies inside the assembly. Don't attempt to remove the plastic reflector strip at the bottom of the front piece... it doesn't need to come off, and chances are you'll break it anyways
The bad news... there is no way to fix the black "checkerboards" attached to the clear lens. It looks like the entire section is melted together, it can't be seperated.
Ward, the tail lights I have lying around look like this:
The drivers side is messed up w/ a BB hole in it. Pass side is OK
Hope that helps you Blade.
Frozer!!!
Jan 19, 2024 04:55 PM
90formulaVortec
Sep 7, 2015 06:54 PM
Jono
Aug 30, 2001 06:20 PM
zupmanZ28
Jul 21, 2001 09:07 PM
CDnAP48
Jun 25, 2001 06:18 AM
