Question about GTA wheels and drum brakes
Old May 18, 2004 | 10:37 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
would i run into any problems with putting on a set of GTA wheels on my drim braked rear end firebird.would i need any kind of spacer fro the front or rear?
Old May 18, 2004 | 11:31 AM
arejay86's Avatar
Car: 1988 IROC-Z
Engine: 305 TPI 30 over
No, because GTA's came stock with rear drum brakes, so the wheel was made to fit both rear drum and disc brakes, not sure about front ones though, even though its extremly rare to see front drum brakes anymore on any car
Old May 18, 2004 | 02:39 PM
91banditt2's Avatar
Engine: 5.7 HSR
ttt
Old May 18, 2004 | 03:39 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Question about GTA wheels and drum brakes
No.
would i need any kind of spacer on the front or rear?
Front, no.
The rear may have had a 3/16" shim/spacer (my 16" formulas had them in the rear) but, they are not needed.
Old May 18, 2004 | 04:09 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Spacers would be needed if you have the aluminum drums, otherwise, everything will bolt right up.
Old May 18, 2004 | 04:19 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Other way around. Spacers required for the cast iron drums. The aluminums drums are thicker so they don't get the spacers.
Old May 18, 2004 | 04:28 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Oops, thankx Goumba. I knew I read something about that.
Old May 18, 2004 | 06:33 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
I just put the 88 GTA wheels from the car in the sig .... on my 88 Camaro like an hour ago actually lol...crazy. Rides fine... no problems. GTA has 4 wheel disc... Camaro has drums.
-Bud
Old May 18, 2004 | 07:27 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I put some GTA wheels on my 88 Formula with drums out back. No problems here either.
Old May 18, 2004 | 08:05 PM
NEEDforSPEED's Avatar
same with my camaro...
Old May 19, 2004 | 09:10 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I did the same thing with my 89 RS but I had the spacers and it looked a little better with them on. I didn't think 3/16 would make a difference but it does.My IROC wheels seemed too far in ward in the rear. GM did it for a reason.
Old May 19, 2004 | 11:36 AM
Car: Camaro
Engine: 3800
Without spacers and with drum brakes on a Camaro it looks like this:
Attached Thumbnails Question about GTA wheels and drum brakes-gtawheels03.jpg
Old Jul 30, 2014 | 12:03 PM
mrobertson's Avatar
Car: 1987 Trans Am
I pulled the rear wheel off of my 1987 trans am and found a shim or spacer between the wheel and brake drum . Does anyone know what this is
Old Jul 31, 2014 | 02:14 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
My car has GTA wheels with no spacers and drum in the rear....
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
