Was my car painted before?
Old Jul 27, 2014 | 01:19 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
My 86 t/a is white and has a few paint issues here and there because of the clear coming off. I'm unsure if it is original paint. Even though it's been so long the car has been kept garage most of its life and is only just hitting 120k.
My issue was with pictures I'm seeing online the gauges are white on the white cars. My interior is Grey and black.
Also on the subject I wanted to get it painted although maaco (usually a cheap place) quoted me 1800 for four year paint!
Old Jul 28, 2014 | 07:33 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Was my car painted before?
Do you see a different color in any hidden place on the car? (under some ground fx, spoiler, trunk, engine bay, wheel wells, etc)? I'd look up and see when they started spraying clear on thirdgens, if it was after '86 then you'll have your answer.
Old Jul 28, 2014 | 01:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
86 was the 1st year for BC/CC,(Base coat,Clear Coat)the gauges,by White do you mean the back plate?if so,no,they were all Black with White Didgets and Red needles.And do what RedLeader says and also check under the Carpet.
Old Jul 31, 2014 | 10:59 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
you and everybody else, IMHO would be better off to forget 2 stage paint. just shoot it in acrylic enamel with hardner added and be done.
Old Jul 31, 2014 | 07:36 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The paint may be original, condition of the paint can depend on a lot. If it was garage kept or stored outside. How well the paint was cared for, the color (dark vs light) temperature, etc. My Camaro was that purple haze metallic and it was in wonderful shape 15 years later when I repainted it. I wanted a different color.
Old Aug 1, 2014 | 08:20 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
86 was the first year of bc/cc and was apparently done very poorly, especially in the CA plant. It probably is the original paint coming off.
The guages were the same on all color cars.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
kyle5647
Aug 7, 2015 03:08 PM
