Where to find hood lifts for fiberglass hood?
Subscribe
Sep 26, 2000 | 08:27 PM
I just went to half a dozen parts stores, and the ones that didn't show "not available" showed the same part number as the lifts for a steel hood. I'm sure they'd fit just fine, but I'd rather not have the hood snap in half when I tried to close it. Lifts for the fiberglass hoods must be available somewhere, after all the early crossfire cars had glass hoods... Anyone know where I can find these or will I end up adapting a prop rod to hold my hood up?
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Reply 0
Sep 26, 2000 | 10:12 PM
82-84 camaro was the years for the fibergalss hoods,,, that is what you would need to ask for at a parts store. Or 1404 5326 is the *factory* part number for the supports,,, any parts store should be able to cross reference it for the correct replacement
<A HREF="http://anzwers.org/free/gta" TARGET=_blank>87 Firebird
84 Camaro</A>
Virtual Racing
- intelligence is learned, ignorance is universal
Reply 0
Sep 26, 2000 | 10:30 PM
I had them look up the part for an 82 Camaro, and it was no different. Apparently they just have an "82-92" parts look up for that part. I'll try having them cross the factory number, though they'll probably try to sell me one for a steel hood still. At the places that had a book you could look up your own part number in, they showed the same p.n. for "hood" and for "hood, steel"
Reply 0
Sep 26, 2000 | 11:25 PM
I believe Mighty Lift(?) is the one that has lifts for fiberglass hoods,, Autozone carries them
Reply 0
Sep 27, 2000 | 07:44 AM
Your local junk yard has plenty in stock. Go find a hood that won't stay open and nab the hinges. My IROC hinges were totally shot, but work PERFECTLY with my harwood. I can position the hood at any point and it stays.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Reply 0
Sep 27, 2000 | 10:58 AM
same here, ask around this site to see if anyone has shocks that won't hold their hood up anymore.. that will work fine for you
91 rs convertible, K&N, Edelbrock open element cleaner, 3.73, B&M shifter
Reply 0
Sep 27, 2000 | 09:42 PM
Well, it turns out I would have wasted my money if I had bought new lifts. After reading the replies about using worn lifts for steel hoods I first smacked my self in the head and said "Duh! Why didn't I think of that" Then I went ahead and installed the new hood and tried to close it. Sure enough, the lifts that were showing signs of weakness on my steel hood are perfect on this one. Thanks for the ideas!
Reply 0
Sep 30, 2000 | 10:29 PM
Man, my struts must really be worn out, cuz they won't even hold my Harwood open. I am resorting to the "vise grip" method on the shaft of the hood strut. Guess I'll have to go to the boneyard.
Reply 0
Subscribe
