cracks in ground effect paint
Old Sep 29, 2000 | 02:17 PM
theformula's Avatar
I added 89 GTA ground effects to my formula last month. And got them painted 2 weeks ago with poly-urethane (flexible paint).
I noticed the paint is cracking on the corners of the ground effects. Mostly on the rocker side ground effects. Is this normal? Do all of you experience the same thing?
thank you
Old Oct 1, 2000 | 09:03 PM
Metallica383's Avatar
No that is not normal if the paint job is done correctly! Was the paint chipping in the same areas before the car was painted?
Old Oct 2, 2000 | 08:31 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If flexable primer isn't used on those pieces, they're toast.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 3, 2000 | 02:05 PM
zee28's Avatar
Car: 86 iroc
I agree ,sounds like no flex primer was used or a poor prep job was done.all the old paint should have come off first.I had the same thing happen to my iroc 6 months ago.I took it back and they did it right.even sanding old paint and then using primer wont work for long.the old stuff if any needs to come off.the primer has to be applied to a clean base,old sanded paint is not clean.
~mike~
1 superclean 86IROC-Z
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
mikey8494
Aug 22, 2015 07:57 PM
92firebirdchris
Aug 14, 2015 11:56 AM
