Paint
Old Oct 5, 2000 | 01:20 PM
knighthelm's Avatar
Paint
I have a 87 camaro. The paint is defective and peeling in places. I was wondering when I get the car repainted do I have to strip all the old paint off and start from the bare metal or can I fix the trouble spots and go from there?
I want to keep the car for a long time so I want to do it right.
Old Oct 5, 2000 | 02:44 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Ideally you want to just remove the layer that's coming off. Factory, baked on paint sticks to the metal better than anything that can be sprayed on later, so you're best off leaving it there.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 5, 2000 | 04:48 PM
odin65's Avatar
This is absolutely incorrect! The reason your FACTORY PAINT would be peeling, is because of a problem GM had with the adhesion of the basecoat to the primer. This problem was most prevelant on the top side of the car because it received the most direct sunlight. Your best bet is to have the car stripped to the bare metal, then repainted by a quality shop.
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
