Shifter Knob
Shifter ****
I want to replace my round shifter **** on my 84 Z28 because the old one is cracked.
Here's my Q...
How do you get the stupid thing off!!!
I can't turn it or anything. Are these Pressed on? If so, what tool do you need to remove it?
Thanx
Randy
84 Trans AM LG4, 700R4 T-tops
1984 Z28 L69, 5 Spd, T-tops
"Don't sweat the petty things...Just pet the sweaty things"
Here's my Q...
Thanx
Randy
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
little clip that looks like a long staple...
remove from front side using very flat tip screwdriver...
Duffster (age 31)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),84' 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Duffster (age 31)
AND THE TIRES:
Are you talking about an automatic shifter or Manual? I know the automatic has that staple in the front. (My TA has the auto)
I don't see anything like that on my Manual shifter for the Z28
Randy
Randy
By the way Duffster. I notice you're in my neck of the woods. heheh. Good to see someone from around here
Randy
Randy
Guest
Posts: n/a
Take this link: http://www.iroc-z.com/howto/howtopag.../interior2.htm
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
Ok. I think I'm not making myself clear. hehehe
I'm trying to remove a MANUAL shifter ****....
Randy
Randy
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Unscrew it.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
I was hoping it wasn't that simple haha. I can't get that thing to turn to save my life.... Oh well, time to soak in penetrating oil then.. Thanx Jim
Randy
Randy
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I dont know id the GM ***** do this, but under most manula shifter ***** there is a chrome piece of metal that you back up onto the shifter **** to keep it in place. Try turning the metal piece under the **** if there is one. That should let you remove the ****.
dude, I had the same exact problem, and it was a B*TCH to get off! =/ Its supposed to just unscrew, but its really hard sometimes, so this is what I did. First I had to cut off the rubber covering of the **** which took some blood and time away from me. After that, I had to take a monkey wrench and twist the f*cker for two days on and off... it finally popped off (after I had broke all the plastic tabs on the ****) Watch out though, my new European shifter **** doesnt fit on good, so it looks like crap right now.. I wound up stripping the ****. Be ready to cut it down and have a cast and die set to re-threat it. I have to shell out another $50 cause I wasnt warned.. hehe =P
HTH
HTH
Night rider327
Feb 25, 2016 09:50 AM
