Painting interior panels ... steps and paint type?
Old Oct 15, 2000 | 10:02 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Ok, I can only find panels that are NOT the color I need. Although people say to paint them.
What are the steps to paint plastic panels (door, console, etc)
I have heard you need to chemically prep the surface, and then use a special type of paint that is almost a dye.
If you just use standard type of paint it will peal an chip.
Anyone with experience in this area?
MArk.
Old Oct 15, 2000 | 11:05 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
yes, it is spray dye you use. prep plastics by cleaning with acetone or laquer thinner completely. For plastic,, go over the pieces with a scotchbrite pad (similar to what you use to scrub pans with)to give the dye a 'porous' surface to stick to otherwise it will rub off easier. vinyl usually readily accepts dye. the 2 major good brands are mar-hyde & duplicolor,,, I preferr duplicolor because it has the fan spray tip covering more area. I've used both and they seem equal in quality with ease of spraying going to duplicolor. As with painting,,,don't try to get the color in one thick coat.
<A HREF="http://anzwers.org/free/gta" TARGET=_blank>87 Firebird
84 Camaro</A>
Virtual Racing
- intelligence is learned, ignorance is universal
Old Oct 16, 2000 | 12:48 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I use the SEM brand dye. Seems to work fine. On the can, it will list what prep is required an what needs to be applied before the dye. SEM uses SANDFREE before the dye is applied.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Oct 16, 2000 | 07:11 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I painted a pair of kick panels with some $4 can of vinal paint from Parts America. They've been in the car since July, and have been kicked a few times. So far they still look perfect.
By the way, the door sill is original, and unpainted. As you can see, the color match is excellent.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
[This message has been edited by Jim85IROC (edited October 16, 2000).]
Old Oct 16, 2000 | 01:41 PM
Wolfcoast's Avatar
I've used the duplicolor vinyl paint in my Z28. I did a complete color change.
You Definitely want to be careful about your coat thicknesses... Make sure you use very light coats. If it gets too thick, it will scrape off. Several light coats works perfect.
Good luck
Randy
84 Trans AM LG4, 700R4 T-tops
1984 Z28 L69, 5 Spd, T-tops
"Don't sweat the petty things...Just pet the sweaty things"
Old Oct 16, 2000 | 02:01 PM
EVILFACE's Avatar
I used the interior panel paint from Next Generation:
http://www.yearone.com/nextgenparts/...nterior20.html
Stuff works great. I just scrubbed the original panels with a ruff spong and dawn soap, then sprayed the bonding agent and then the final color paint (black of course) and it turned out great. Just go to my site below and see the before and after pics.
EVILFACE
"Never scared of the things men fear"
http://www.evilface.com/evilscamaro.htm
Stock 305 TBI Auto,
Flowmaster Muffler, Full 3" Exaust, B&M Megashifter
Runs A Blistering 16.5 @ 81.5 mph
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
AkDrifted
Aug 17, 2015 07:45 PM
