Need some help about polishing equipment
Old Jan 10, 2005 | 08:23 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
In a couple weeks im gonna take a weekend and polish my wheels. I have read and understand the process but I have a couple questions before I order from Eastwood Company. I know what I need, just not the quanity(don't wanna run short).
How much of this stuff do I need?
Compounds and Buffs:
1) Buff Compound White Rouge 14 oz Tube
2) Buff Compound Tripoli 13 oz Tube
3) Buff Wheels Canton(what size is best 4, 6, 8, or 10)
4) Buff Wheel Spiral(what size is best 4, 6, 8, or 10)
Sandpaper:
I can't seem to find the right sandpaper on the Eastwood Site. Im looking for 180 dry, 320 wet, and 400 wet.......I would perfer the stuff on a roll that you could stick to your finger.
If any of you guys use this stuff and could help I would be very greatful.
http://www.eastwoodco.com
Old Jan 10, 2005 | 10:25 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
these are what i used to sand my aluminum projects, i did not do any wet sanding. 80, 120 , 240, 320. works great on a dremel or air die grinder. get extra arbors they do bend if dropped then they can not be used don;t even try to sand with a bent arbor.
http://www.eastwoodco.com/jump.jsp?i...ORY&itemID=443
this is real nice for a bench grinder for flat parts
http://www.eastwoodco.com/jump.jsp?i...39&iSubCat=445
here is my newest tool that works great and may be just the ticket for your rims if you have air.
http://autobodystore.net/Merchant2/m...tegory_Code=T2
you will need at least two buffs one for each product. do not mix products on the same buff or it will not produce the results you need. size depends on what your using to buff with i would guess and reccomend a bench grinder. i used the 5 " and 7" i liked the 7" better. i also had some 4" or maybe 3 they were small. nice for little parts but forget it for bigger projects not enough room.
jeff
jeff
Old Jan 11, 2005 | 08:11 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
I bought that sticky back paper on rolls from Lowes or home Depot. The key with handsanding is dont try to scrimp on the paper. Use it liberally, Cause on metal a small piece is shot after about 7-10 swipes.
Not sure about the size of the wheels, but i would think the smaller wheels would work better if youre needing to get into the spaces on those rims.
Sanding is fun for the whole family!! :lala: :lala: :lala:
Old Jan 11, 2005 | 07:09 PM
KonArtist's Avatar
Engine: 350 HSR
Axle/Gears: 3.42's
What about the compounds? Do you guys know if one tube of each compound will do 4 wheels.......will one buff for each compound last 4 wheels also?
Thx
Old Jan 11, 2005 | 08:00 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
Engine: Rebuilt 350 TPI
I just ordered 3 compounds and 4 wheels from eastwood to do my wheels, for the 4 step process. I was worried there wouldnt be enough compound, but there is MORE than enough compound in the tubes, I could do every piece of metal on my car with it lol. The compound comes in a tube a bit larger than a can of bisquits, if that helps any.
Old Jan 11, 2005 | 08:20 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Whack job.
Metter, GA... a seed from the sower. Great deer hunting!
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
indygene
Sep 26, 2015 11:21 AM
wstephan96
Sep 25, 2015 04:28 PM
