4th generation wheels question
Car: 90 Formula
My dad seems to think if I buy adaptors to go to 4th generation wheels the axle will become weak because you are spreading out the width of the axle (or something like that). Has anyone heard anything about this? Has anyone with 4th gen wheels ran into any problems w/ bearings etc. any thing will help
350 TPI, K&N filter, Moroso cam, Airfoil, Accel fuel pressure regulator and gauge, Hooker headers, Flowmaster 3" catback ...more to come.
if u get a 4th gen rear axle, you will only need spacers in the front. i heard that spacers under 1/2" or 3/4" are ok to use, but large ones are not that great.
dont hold me to that because im not sure, hopefully someone else can verify those #'s and give you some specifics.
Car: 1985 Trans Am
Axle/Gears: 3.70
I've not heard of anyone having problems with their axles due to spacers. Theres quite a few people who have had them for a couple of years now with no probs.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Traditional spacers can cause the lugs to shear because all of the force is at the end of them, but the spacers needed for the 4th gen offset are so large that they bolt to the stock lugs, and then the wheels bolt to new lugs that are part of the spacers. Essentially axle doesn't have any idea whether that extra space is part of the wheel or part of a spacer because the spacer and wheel are bolted together.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
