Aircraft remover question
Car: '88 Red Trans Am w/ T-tops
Are you supposed to use this when trying to polish aluminum? I thought i read in a tech article that this should be used but i don't see why. Any clarification would be great.
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
It is used to speed up the removal of the clear coat on the rims. You could sand it off but you'll see that if you can eliminate some hours of sanding you'll be better off
nevermind i found it, I was thinking of 3M Marine aluminum restorer. How much better is the shine when polishing with this rather than using buffing compound and a drill?
Car: 1989 IROC-Z
Engine: 383 stroker
I've never used that 3M stuff, but it sounds like its something you would use to maintain the polish job. I could be wrong since I've never heard of it before though
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
aircraft remover works reaaaaaaly quickly. i had 3 layers of rattle can on my valve covers. watched the paint bubble up before my eyes. but keep it off your skin, it itches a LOT
