Help with racing rims, please!
Old Mar 23, 2005 | 05:31 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I need a little help here. I did a search and didnt find what I was looking for.
I want to be able to run my new Pro Stars without changing the studs off the rearend and front end. Right now the studs will not be long enough to thread the lug nut on with the Pro Stars. And I do not want to change to longer studs because I will no be able to run my GTA rims on them with the black caps. I would have to cut a hole in the caps to put them on, or run the GTA rims without them and have long studs sticking out through.
What do I do??
Old Mar 23, 2005 | 06:35 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
When I had my Weld Draglites I had to use a set of lugnuts that go down to the studs I cant remember what the style of lugnuts is called but im sure that somone could tell you. They are really just regular lugnuts with a longer skinnier extension on the threaded side to thread onto the short studs without changing them you have to use them with all of Welds rims when not changing your studs so if you go to a parts store they should know exactly what I am talking about.
Old Mar 23, 2005 | 09:24 PM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Certain wheels need certain lugnuts. Would spacers work on the factory wheels with the longer lugs?
Old Mar 23, 2005 | 11:14 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Sent you a PM
Basically, if you have stock studs, you would need a "shanked" ( i beleive thats what its called) lug nut.
Our cars take the 12x1.5 size, mine are made by Weld.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
gord327
Oct 3, 2015 01:25 PM
