Removing paint from Iroc rims.
Old Apr 11, 2005 | 04:37 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I have 3 layers of paint on my iroc rims. The factory gold, then factory color blue over the gold, and now the current dark purple over the other 2.
How can I remove these to polish the wheels. Can I bead blast them with a light abrasive like walnut shells? I heard that full out sandblasting will pit the rims. I've also read about aircraft paint removal, but will that actually remove it all?
The rough aluminum areas on the rims are painted and I can't see the paint remover removing it all.
I would really like to strip thes down and polish them back up.
Old Apr 11, 2005 | 05:01 PM
Haggard's Avatar
Car: Aquiring a Thrid Gen soon
Use aircraft remover it works. Sandblasting wil be to expensive. Just put the remover on really thick.
Old Apr 11, 2005 | 05:04 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Re: Removing paint from Iroc rims.
This is what you want. With three layers of paint, it may take a few applications to get it all removed, but it will do what you want very easily.
Old Apr 11, 2005 | 05:09 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Is there a certain brand thats better. Our Walmarts in canada don't carry anything called "aircraft" paint remover.
What do you guys use then to polish the wheel once the paint is stripped. I imagine the aluminum under the paint would be pretty dull in appearance.
Old Apr 11, 2005 | 06:21 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Look at the sticky at the top of the board. It tells you everything you need. Its called how to polish your rims or something like that.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
mustangman65_79
Aug 11, 2015 03:17 PM
3rdgenparts
Aug 8, 2015 07:09 PM
