Stripping paint on wheels via aircraft stripper
Old Apr 19, 2005 | 08:51 PM
UDAMON's Avatar
Car: Mazda Protege5
ok well we tried a coat (after already stripping the clear coat using something different) and we waited 40 mins with not so impressive results.. i mean i got a little off but i had expected more from this kind of product (not to mention the health hazard ). so i was curious as too how think you guys puts yours on and how long you let it sit. maybe even how much you used?
Old Apr 19, 2005 | 09:23 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
When I use it, I only let it sit max 30 min, after that it starts drying and harding back up. after about 20 min Ill usuallly use a wire brush not a drill one, and go over to get the majority off, then put another coat of paint stripper on.
Old Apr 19, 2005 | 10:06 PM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
I never let it sit over 10-15 minutes. Works fine for me! Are you talking about the one in the spray can or the one with the screw-on cap? The spray can stripper doesn't give me very good results. I use the one with the screw on cap and apply it with an old paint brush.
Old Apr 20, 2005 | 09:19 AM
UDAMON's Avatar
Car: Mazda Protege5
nah we are using the screw on cap container. so its just gonna take a couple coats then?
Old Apr 20, 2005 | 11:15 AM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
When I tried it a few weeks ago, it didn't look like it took anything off at all. I tried polishing a spot that I knew had clear coat on it before, and it started to shine. It had stripped it... just didn't really look like it did.
Old Apr 20, 2005 | 07:05 PM
Car: '87 Camaro SC
Engine: 305 LG4
Yeah, usually takes me two coats to get it all off. I use a paint scraper on it to help it along.
Old Apr 20, 2005 | 09:01 PM
J-Bru-Ha Z-28's Avatar
Car: '91 Z-28
You guys are talking about the jelly like stripper correct? If so the trick to getting that stuff to work is applying it in generous amounts more like globing it on not brushing it. A thin coat will do nothing, how it works is when applied correctly the air dries the outer part of the stripper forming an air tight seal, the vapors then go to work under the dry "skin" and eat away the clearcoat or paint that you wish to remove. worked great for me, you might need to do two applications depending on the complexities of the wheel you are stripping.
Old Apr 20, 2005 | 09:02 PM
StealthElephant's Avatar
Car: 87' Iroc
Wire brush, 10-15 minute set time, lots of elbow grease, 3-4 coats to really get everything off.
Old Apr 20, 2005 | 09:47 PM
UDAMON's Avatar
Car: Mazda Protege5
awesome sounds good.... thanks a lot for the tips!
Old Apr 20, 2005 | 10:57 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
I globbed it on and it seemed like by the time I was done going around the wheel.. the clear was crinkled and ready to come off. Perhaps I was using something different.. weird.
-Bud
Old Apr 21, 2005 | 02:40 PM
Nikole's Avatar
Car: 1992 RS
this is how we did my rims also and it worked good...of course it took a little elbow grease to get all of it off but it wasnt bad.
Old Apr 23, 2005 | 08:43 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Just now redoing the wheels on my old Camaro. Went to Walmart and got some stripper that has a spray bottle with it, not expensive. Spray it on, wait 20 minutes or so, hit it with the power washer. (wear protective clothes, nasty) Then use some steel wool and stripper to clean it real good, wipe with laquer thinner. Prime and paint. Tried sand blast, life's too short for that.
Vintageracer
Jan 10, 2020 05:33 PM
g.l.mos
Aug 22, 2015 12:02 AM
kah992
Aug 19, 2015 02:55 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
