Tree from hell!!
Old Apr 26, 2005 | 01:17 AM
Gr89RS's Avatar
Car: '02 Z06
Tree from hell!!
How do I get sap off my hood??
Old Apr 26, 2005 | 01:52 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Go to your local Autozone and buy a claybar.
Old Apr 26, 2005 | 02:06 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
bug and tar remover works
Old Apr 26, 2005 | 07:47 AM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
I dunno about that. The bottle I tried just smeared everything around. I could have done the same with water. I still had to use a clay bar to get everything totally clean.
Old Apr 26, 2005 | 10:56 AM
Gr89RS's Avatar
Car: '02 Z06
Will the sap scratch while i remove it??
Old Apr 26, 2005 | 11:59 AM
EvilCartman's Avatar
Car: '82 Z28
It shouldn't if it's still in it's goo phase. I use rubbing alcohol and a soft towel, seems to do the trick even on the old hard sap spots.
Old Apr 26, 2005 | 03:56 PM
1badbowtie's Avatar
Car: 88 Trans Am
Engine: 305 tpi
a trick i use to get sap off is to use mayonaise!!! it may sound weird but it works, try it!
Old Apr 26, 2005 | 04:09 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
WD-40 works nice.
Old Apr 26, 2005 | 04:10 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
I prefer mustard, relish and some ketchup. It may sound weird, but thats cause I made it up
Old Apr 26, 2005 | 04:11 PM
Rossdaddy63's Avatar
Car: 1991 RS
Engine: 305 TBI
i have always had luck with the bug/tar remover. if that doesn't work, a good decreaser will do the trick
Old Apr 26, 2005 | 04:12 PM
Car: 1991 RS
Engine: 305 TBI
*i meant degreaser*
Old Apr 26, 2005 | 04:15 PM
Car: 1987 Z28
Originally posted by Rossdaddy63
*i meant degreaser*
Do you have a fear of the ever so evil "edit" button?
Old Apr 26, 2005 | 04:16 PM
Megaracerx2's Avatar
On Probation
Car: 1986 Trans Am
i needed this thread last week...lol
and 83, that was great
Old Apr 26, 2005 | 04:17 PM
Car: 1991 RS
Engine: 305 TBI
i forgot that was there... my bad
Old Apr 26, 2005 | 04:43 PM
gipraw's Avatar
Car: 2002 Trans Am
Transmission: M6
Clay bar and a microfiber for drying.
Go to an autoparts store, and get either a Mothers or Meguiar's clay bar kit, and clay your hood. by far the safest way to do it.
Old Apr 26, 2005 | 05:04 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
My '94 S10 Blazer had some nasty, hard, dried-on sap spots that took a very long time to remove just one spot of sap with a clay bar. After doing some searches around TGO and talking to the body shop that worked on the Blazer, I used some rubbing alchohol. It worked wonderfully. I put some on the sap spot and start rubbing lightly with a 100% terry cloth towel. Sometimes I would put a few drops on the sap and let it soak in first (and evaporate for that matter since rubbing alcohol evaporates quickly). After I got all the sap off, I then clay-bar-ed the whole car to get it ready for waxing.
Old Apr 26, 2005 | 05:43 PM
Gr89RS's Avatar
Car: '02 Z06
Thanks guys I'll try the clay bar
Old Apr 26, 2005 | 07:34 PM
Gr89RS's Avatar
Car: '02 Z06
The clay bar succesfully removed the sap!!I will now try to clay to clay the hole car for the hell of it, but the lube leaves a residue, the directions say wipe it off, but this doesn't seem like it will be to fun to wipe off!?!
Old Apr 26, 2005 | 08:51 PM
gipraw's Avatar
Car: 2002 Trans Am
Transmission: M6
use quik detailer or a product like that and a clean microfiber. should come off no problem.
one thing.. don't use the clay bar if the car is hot, or the clay itself will leave a residue.. if that happens, you can reclay when cool and it will come right off, or hit it with a quick coat of cleaner wax, and that will fix it up.
Old Apr 26, 2005 | 10:35 PM
Car: 1987 Z28
what would a clay bar do for thw whole car?? just wondering
Old Apr 26, 2005 | 10:42 PM
Gr89RS's Avatar
Car: '02 Z06
Its supposed to get every spec of old crap and smooth the look of the piant..
Old Apr 27, 2005 | 12:09 AM
Car: 1987 Z28
interesting......are they expensive/worth it?
Old Apr 27, 2005 | 12:15 AM
Gr89RS's Avatar
Car: '02 Z06
Well its going to rain here tommorow, so im not gonna do the car for a while, but judging by how well it took the sap off id say it will clean and smooth the hell out of any paint...it comes in a kit for about 10 bux at autozone. Id say its worth it
Old Apr 27, 2005 | 01:16 AM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
A clay bar is definitely worth it. Get a Mother's California Gold clay bar - one of the best.
When I waxed the Blazer last spring, I went over every inch of it with the clay bar first to remove stuff stuck on. There was a lot of small black specs (tar, rubber, and what not) along the bottom of the doors and the rocker panels that would not wash off and would smear when I tried to get it off with my finger nail. The clay bar took it all off very nicely.
Old Apr 29, 2005 | 03:30 AM
82knightrider's Avatar
Transmission: TH200C....700R4
hot water n soap
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
92camaro350cci
Oct 14, 2015 09:29 AM
aaron7
Sep 30, 2015 09:15 AM
dimented24x7
Sep 6, 2015 03:51 PM
