3+ inch drop?
Old May 3, 2005 | 04:41 PM
  #51
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
with a 8.5 wide rim i should really go for a 245 without bulg but you can d0 225..i had a 215 on it but that was a mistake..so i got new ones.....8 wide you can easily do 225 no problem with fitment....well if you tell them you want the rim to fit your car..usually they come in the set offset....for my rims its a fwd rim only in 20's they are rwd...so i did the fwd with a space/adapter
Old May 3, 2005 | 04:57 PM
  #52
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
225/40/18 and 265/35/18 are the exact same over all height.. 25.7 inches tall (i think)
i did that to have a staggered package
the 225/35/20 are just high enough to clear the fenders when the inner fenders are removed so its cool
when you start going up in rim size you have to go down in the 2nd number of the tire size...
225-in millemetres *width of the tire*
35-% of the width of the tire
20-size of the rim
example..
stock iroc size..
245/50/16 is the same height as 225/40/18 and 265/35/18 (with little varience.. .7 inches max)
i work at a tire shop..so this is something i need to know about to perform my daily routines...
iroc2nv
Old May 3, 2005 | 05:26 PM
  #53
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
weird... I had no idea the width number changed the heith as well... weird....
they also have the same proportions... everything is EXACTLY the same except for the width... weird.
Old May 3, 2005 | 05:38 PM
  #54
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
ya not alot of ppl realize this...i tryed to explain i cant go wider cause the height grows to but nobody understood that one...
Old May 4, 2005 | 03:32 AM
  #55
CrazyHawaiian's Avatar
Car: too many ...
I'm running 245/40/18 fronts and I was able to eliminate any rubbing (even at full lock) by adjusting my ride height. Started it off with the fenderwells resting on the tire and raised it up little by little until it was the lowest possible without rubbing. Took a while to get it perfect (driving around, checking, changing, etc). This is one of the reasons I really like the spring pertches (aka weight jacks), you can set the ride height. Then once I set the fronts, I set the rear to match (I dont like a raked look when slammed, I like evenly slammed front and rear). I dont know exactly how much lower it is than stock, but its really low. Looks almost exactly the same as SlammedZ's stance, maybe 1/4 inch difference.
Anyone got some measurements of stock height? I'll try to get some tomorrow from a different car. I also got the camera now, so should have some pics by tomorrow.
Old May 4, 2005 | 08:27 AM
  #56
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
finally some pics from you , ive been waiting for a while to see some pics of the new stance.
Old May 4, 2005 | 01:23 PM
  #57
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
from the white line on my front piece i drew,i sit 5"
from the side skirt white line its 4 1/2"
stock my front was 8" from the white line
Old May 4, 2005 | 02:00 PM
  #58
ScrapMaker's Avatar
hrm, my springs are worn as hell and on my firebird it looks like this...
it feels like I am practically riding on my bumpstops.
Old May 4, 2005 | 02:09 PM
  #59
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Mine is lowered 2.5" all the way around.
Old May 4, 2005 | 02:12 PM
  #60
ScrapMaker's Avatar
what's the link to your page, pwdbychevy?
I think there is a difference in our GFX design... it would probably be best to measure to the transmission mount, or something that's part of the chassis that's consistent from year to year and bird/maro
Old May 4, 2005 | 02:24 PM
  #61
Graboid's Avatar
hmmm, 2.5 inch here too...
Old May 4, 2005 | 02:29 PM
  #62
pwdbychevy's Avatar
It's http://www.cardomain.com/memberpage/781816
Old May 4, 2005 | 02:48 PM
  #63
ScrapMaker's Avatar
how do your headlights compare to silverstars? and what's that dakota digital box do?
Old May 4, 2005 | 03:04 PM
  #64
pwdbychevy's Avatar
The silver stars are probably brighter and the box recalibrates my speedometer since I have 3.73 gears.
Old May 4, 2005 | 03:13 PM
  #65
ScrapMaker's Avatar
can that not be done with the computer directly? I didn't realize you had to get a specific box to do that...
Old May 4, 2005 | 03:35 PM
  #66
pwdbychevy's Avatar
i don't mean to get off the subject but it's the easiest way to recalibrate your speedo. if you burn your own chips like i do, you can get close but it's not dead on plus you might run into stalling problems. do a search in the tranny and drivetrain section for dakota box or sgi5.
Old May 4, 2005 | 07:14 PM
  #67
iroc2nv's Avatar
Axle/Gears: 3.45
you are really that high ian?
i dont think you are that high man...you sure you measured right?
here is a small pic of what mine is like on my bags with 20s...
Old May 4, 2005 | 10:36 PM
  #68
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
I think Graboid's car sits perfect!
Old May 5, 2005 | 12:00 AM
  #69
Car: too many ...
Well I couldnt get any shots on level ground to show the stance and ground clearance, my only flat stall is full. My carport is raised compared to the sidewalk so it shows the chassis clearance real good. I'm currently re-doing the front suspension on my 89IROC and its in pieces. But anyway, I did snap a teaser pic of the 91Z28 out in the driveway. Didnt take too many pics because the car is sitting on an uneven incline, kinda screws up the stance. I figgure when the space is open I'll take some real pics with the tape measure and stuff.
And here's a pic of it sitting next to my 92B4C with stock springs (I think). Remember, these are sitting on an uneven incline so probably a bad idea to even be taking pics regarding stance ... here goes anyway.
Old May 5, 2005 | 12:04 AM
  #70
Kandied91z's Avatar
you have 3 of those bad boys now...
Old May 5, 2005 | 12:08 AM
  #71
Car: too many ...
Yup, I picked up that B4C for $1500. I've been driving it to work while messing on these other two (doing suspension on the IROC and T56 swap on the Z28). I'm gonna fully restore the B4C to factory stock perfect condition and completely polish the TPI, then I'm gonna sell it and use the profits on my motor project. I'm a lucky guy!! right place at the right time.
Old May 5, 2005 | 02:37 AM
  #72
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
what do you mean gerry? do you think im higher or lower then what i said?
Old May 7, 2005 | 06:05 PM
  #73
Fast_83_Z28_350's Avatar
Car: 83 Z28
Transmission: t 350
hey slammed_z....from where u said u sit 4 1/2" my car sits 6 1/2". i have the 83 style ground efx and im not to sure if there is a difference..but how much do u think i would have to cut off the front coils springs to bring it down to around 5"???
Old May 8, 2005 | 01:44 AM
  #74
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i think your sitting around the same height as him fast 83 the 83 ground effects are like 2 - 2 1/2 inches longer i believe. Someone correct me if i'm wrong. I'll compare the 3 tomorrow.
Old May 8, 2005 | 02:02 AM
  #75
ScrapMaker's Avatar
to measure properly you really need a common point of measurement... like the floorpan or something.
Old May 8, 2005 | 03:03 AM
  #76
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
ya its true usin a frame is usually a good way to measure..only thing is i got alot smaller tires them more camaros/firebirds..so i always will have about a 1'' lower then most...unless you do major suspension modes
and ya the ground effects are different..not a huge amount..but about 1/2 to an 1" difference
Old May 8, 2005 | 05:57 AM
  #77
Graboid's Avatar
true, but having wheels in a overall diameter which is less than stock looks wrong, especially when the rims are 17's or more.
Old May 8, 2005 | 12:39 PM
  #78
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
to you it may...but imo i find i still like it....ive never like any tire over a 40 series...i could do one but i would have to raise my car..and that just will not happen...but to each his own
Old May 8, 2005 | 01:32 PM
  #79
ScrapMaker's Avatar
I think his car looks fine... but personally I would just go with 245 40 18... since that's the overall diameter as well.
Old May 9, 2005 | 01:59 AM
  #80
Car: 83 Z28
Transmission: t 350
hey 87CIZ j/w if u got those ground efx measured.....if anyone else knows the size difference between the 82-84 ground efx to the 91-92 ground efx it would be greatly appricated.....deciding on wether to keep my car and put some more mods on it or to sell it and get a forth gen
amargari
Nov 10, 2015 02:09 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
