Cleaning rims
Old May 2, 2005 | 04:14 PM
gogo90camaro's Avatar
Car: 91 Camaro RS
Engine: 5.7
Cleaning rims
I have the origonal 15x7 painted rims. The front rims are stained with the brake dust. I cant get it off just with soap and water. Any ideas on what I could use to cleam them with out hurting the paintor tires? Please help me. Thanks Gregg
Old May 3, 2005 | 05:04 PM
Car: 91 Camaro RS
Engine: 5.7
anyone have any ideas. i have only a weeks and a half left till prom.
Old May 4, 2005 | 08:42 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
get a rim cleaner from the parts store. I recently just bought the dupont teflon wheel cleaner which cleans rims, tires, and bugs and tar from the cars paint. I havent tried it yet but if i use it saturday ill get back to u on how it works. But get a good wheel cleaner if ur in a rush. Good companies are EAge 1, Meguiars, Dupont, and some others
Old May 4, 2005 | 09:48 PM
gipraw's Avatar
Car: 2002 Trans Am
Transmission: M6
try using a cleaner wax, it night cut through the crap for you.
Old May 5, 2005 | 08:09 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Oh man.
I have white factory-clear coated RS 15x7 rims and they get coated with brake dust in about 2 or 3 days. I know it's because of my sticking caliper, but to clean it off, I bought 4 bottles of "Greased Lightning Blast" at Wal-Mart. It comes in an orange bottle and is really cheap - about $3 for a 32 oz. bottle. I spray it on, get a semi-stiff brush, and go at it. I go at it like wet-sanding, spray, brush, and keep spraying while brushing. If you let it dry, it will just stain it again so keep it wet, then after you are done, hose it off.
That gets a good deal of it off, but on the really harsh stains, I use any heavy-duty degreaser that you can find at most hardware stores. Doesn't matter which kind and I usually go for the stuff that seems to be the strongest (look for the uses on the bottle and look for things that clean driveways, garages, etc). I use that sparingly and it doesn't strip the clear-coat or ruin the paint, but takes really stubborn tar/dust/anything off.
Hope this helps
Old May 5, 2005 | 08:36 PM
gipraw's Avatar
Car: 2002 Trans Am
Transmission: M6
next time you get them cleaned, put a coat of Metal Armor Paint and Hard Surface Polish and then a coat of Metal Armor Final Polish and Sealant.
I use that process on my C5's, and the brake dust and crap wipes off with a soft towel and quick detailer. even brake fluid came right off when I had a leaking line.
Give it a try, well worth it.
Old May 5, 2005 | 09:39 PM
Car: 91 Camaro RS
Engine: 5.7
thanks ill have to give that a shot.
birdman_29
Jan 7, 2017 08:24 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
