Will C5 wheels fit a C4?
Old Jun 14, 2005 | 01:13 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I have a set of C5 wheels off my 97 Vette up for sale and a guy wants to know if they will fit his 1992 C4. If not what does he need?
Old Jun 14, 2005 | 01:31 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I believe they should fit fine.
84-87 had the odd offset, 88-96 I believe have a very similiar if not the same offset and backspacing as a C5.
here is a site with specs, since the table below my not format correctly,
http://skulte.com/adapterfaq.html
Rim Name Size Offset Backspacing Suggested Thickness (3rd Gen)
Corvette 84-87 16x9.5 38mm 6.6" 2"
Corvette 88-96 17x9.5 56mm 7.3" 2.25"
Corvette GS ZR1 style 17x9.5 50mm 7" 2"
Corvette ZR1 style (Low Offset) 17x9.5 38mm 6.7" 2"
Corvette ZR1 style (Low Offset) 17x11 36.5mm 7.397" 1.25" Rear
Corvette ZR1 style (High Offset) 17x9.5 56mm 7.4" 2.25"
Corvette ZR1 style (High Offset) 17x11 50mm 7.93" 2" Rear
C5 Corvette 97-2000 17x8.5 front 56mm 6.8" 2"
C5 Corvette 97-2000 18x9.5 rear 63mm 7.6" 2"
C5 Corvette Z06 17x9.5 front 54mm 7.2" 2.25"
C5 Corvette Z06 18x10.5 rear 58mm 7.9" 2" Rear
C6 Corvette 18x8.5 front (GM 9594351) 58mm 6.53" 2" Front & Rear
C6 Corvette 19x10 rear (GM 9594353) 79mm 8.11" 2.25" Rear
Old Jun 14, 2005 | 04:05 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
SWEEEETT!!!!
Thanks for the info. Really appreciate it.
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
milk
Aug 10, 2015 06:26 PM
