Clear turn signals
Old Jun 28, 2005 | 08:36 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Clear turn signals
Where do I find the clear front turn signal covers? Who carries them? How much are they? Are they hard to swap out? Are there also clear side ones?
Old Jun 28, 2005 | 09:57 AM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
go on ebay motors.com
in the search bar put ***85-92 camaro***
youll see a few auctions for clears for less than 20 bucks
The camaro front turn signal clears are 50 bucks dont know bout that install
SIDE SIGNALS
they are easy as crap to swap out...takes 10 min if you include maybe jacking up the car to make it easier there are these two little metal pins that hold the cover on...you push them back the opposite way they are set at and youll feel resistance and think youre gonna break them but you wont just keep pulling till you hear it pop and then take it out set the new one in and figure how to get the pin in there properly (how it was when you pulled it out) and push it back over into the original position snapping it into place then just readd the bulb into the cover
Old Jun 28, 2005 | 01:21 PM
Dark Mavis's Avatar
Car: 94 Camaro Z28
Engine: 5.7L
Axle/Gears: GU5 3.23
The front turn signals are a matter of two bolts each, and you honestly don't have to even jack the car up if you can fit under it outright. The trick is simply finding the right style, as far as I know, there are a few different styles (I had to change mine when I changed my front bumper).
Old Jun 28, 2005 | 04:15 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can also buy them from www.procarparts.com for $30.
Prodigious
Nov 7, 2020 09:23 AM
Fronzizzle
Mar 18, 2019 08:29 PM
dibella989
Sep 1, 2015 04:12 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
