bmw rims... need help
Old Jul 2, 2005 | 10:34 AM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
i was looking at getting these rims:
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
i know the lug pattern will fit, but does anyone know anything about the offset, or if the hub on our 3rd gens will fit into the back of these rims? any info would help.
9Jx18 ET20 5X120 lug pattern
Old Jul 3, 2005 | 02:54 PM
joekickass's Avatar
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
They will fit, just make sure they are 5 or 7 BMW, 3 doesn't work out.........
Old Jul 3, 2005 | 10:11 PM
Dingley's Avatar
Engine: LG4 305
but what if the hub bore is too big for the hub on the car... will that make a difference?
also, can i just use the same lug nuts that i already have.
Old Jul 3, 2005 | 10:36 PM
joekickass's Avatar
Engine: 2.8
Transmission: auto
you may think that I didn't mention the detail, in Taiwan, there is no rim for thirdgen, so I must find some thing to instead, the BMW is the only answer, I had tried 2 set, the first one is not good, the hub center had been fix and became bigger, so I custom 4 center rings to clean the distance to make them stay on the bolt of car, but you can see that the bolt of front wheel is taped, the custom center ring is not "long", so those rim didn't work well, than I found another one which didn't be fixed, I used them without any modification.......
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
NEEDforSPEED
Oct 9, 2002 11:45 PM
F0xBody50
Apr 17, 2002 07:48 PM
Nightcruzer
Jan 3, 2002 08:01 PM
[-sLaYeR-]
Jun 7, 2001 10:29 AM
