Getting SMALLER Wheels
Old Jan 24, 2001 | 03:26 PM
HFactor's Avatar
This sounds backwards, but, I have an 89 IROC. Up here in NH, those big 16 inchers are too wide and pricey to run snow tires on and I want to be able to run this car in the snow. Right now, I'm running my 2nd Gen that gets 14 mpg, arrgh! Does anyone know what size/offset/backspacing I could run if I were to get some cheapie steel 15 inch wheelsand put some fairly skinny snows or all season radials? Any info would be much appreciated.
Old Jan 24, 2001 | 08:30 PM
Andy89RS's Avatar
Go to a local junk yard and grab the wheels from an early thirdgen. LOTS of the early years had 15" wheels, even some later years had 'em...
Old Jan 24, 2001 | 08:59 PM
3rdGem's Avatar
It's even easier than looking for thirdgen; Most all GM cars and 1/2 ton (two-wheel drive) trucks have the same bolt pattern (ex: 68 Chevelle, 72 Nova, 74 Cutlass, 76 step-side pickup, 78 Buick regal, all the way up. You shouldn't have to pay more than 20 bucks per wheel at a junkyard. 15's will fit over your calipers. You might even get away with 14's, but check it out first. Way back when, I had 14X7 Enki "Blades" on the front of my 85 T/A with 15x10 in the back. I know, I know.....tacky as hell.
'88 Formula 350
Bright (VERY bright) red. Mods? yep, but never enough!
Check out the newest f-body site: http://www.lastgen.com/
gta892000
Aug 11, 2019 11:16 AM
Doobie52
Sep 11, 2015 06:19 PM
DARKmj16
Sep 9, 2015 04:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
