Pinstriping
Old Oct 15, 2005 | 03:04 PM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
Transmission: Automatic
Pinstriping
My pinstriping on my car is all cracked and faded and i'm wanting to remove it what can i use. I have tried tar and bug remover but that don't work. I don't want to scrape it off because of the paint
Old Oct 15, 2005 | 05:07 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
i doubt that there is going to be any chemical to remove it. The only way I know of that works is to use a good blade. Just use water with alot of soap mixed into it when you scrape.
Obviously wait for others to chime in before you attempt that. I have only taken a pinstripe off when the paint didn't matter during body work. Good luck and if anything else, this was a free bump
Old Oct 15, 2005 | 05:12 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
You could use a hair drier or a heat gun. Then use some goo gone to remove the residue. Just another option for you.
Old Oct 15, 2005 | 07:14 PM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
If you have a varible speed drill go to the local auto detail shop and pick up an item called thr eracer pad they work great I used one on my friends explorer didn't scracth the paint. You should be able to ask to see one I don't have a picture of it
diana227vegas
Jul 8, 2016 12:27 AM
Lbibb
May 5, 2016 12:00 AM
Jsapp38
Nov 13, 2015 07:38 PM
rscamaro305
Sep 22, 2003 09:35 PM
