firebird taillight mod
Old Nov 16, 2005 | 04:56 PM
casebaseball205's Avatar
anyoen have one....seen one?
pics please
i searched and came up with nothing
Old Nov 16, 2005 | 05:05 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
what kind of mod? I've seen a few with corvette lights, "birds" that light up with the brake lights using LED's, painted, blacked out, etc...
Old Nov 16, 2005 | 05:14 PM
anything
lookin for ideas
Old Nov 16, 2005 | 05:56 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
Old Nov 16, 2005 | 05:57 PM
Car: 1990 firebird
Engine: 3.1 v6
Old Nov 16, 2005 | 07:22 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
There was a guy at a Houston meet that had a cool mod. It was some kind of box that rewires the taillights. When you hit the turn signal, instead of just the one light blinking, it makes the inside light come on, then the middle half a sec later, then the outside half a sec later, really cool effect.
Old Nov 16, 2005 | 08:12 PM
sequential lights i think those are called.
those are pretty cool. i like that firechicken thing.
Old Nov 16, 2005 | 08:45 PM
Car: 1990 firebird
Engine: 3.1 v6
thanks, i did this mod quick..If you take your time and do it right it will look 10 x better. I even spilled some thinner on the plastic part and took off the clear coat. Its alright all i need is a new plastic and some more time. overall i like the mod . Cheap and easy
Old Nov 16, 2005 | 08:55 PM
did you cut out the outline or what.....?
Old Nov 16, 2005 | 09:29 PM
Car: 1990 firebird
Engine: 3.1 v6
i bought a decal set from ebay. Sanded the paint from the inside of the plastic cover . IF you sand down enough you will sand down the bird and the paint. So after i sanded the factory pheonix i placed the decal on it. Spray it with some krylon plastic and carefully peeled off the decal. I then ran the Hatch light (the one that is by the motor) and placed it right under the lock for the hatch. I had to splice into the tail light btw
Old Nov 16, 2005 | 10:15 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Old Nov 17, 2005 | 09:59 AM
anybody have pictures of the corvette mod?
Old Nov 17, 2005 | 12:42 PM
Speedy Mike's Avatar
Car: 92 Firebird Conv
Transmission: T-56 w/3.42 Posi
i did the light up bird, except i did it a different way, also it looks 10x better in red, then wired it to the license plate light.
Old Nov 17, 2005 | 10:45 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Please show us!
That is pretty darn cool. I'd love to do that in which case I would need detailed instructions being that I am spaz and all.
Old Nov 18, 2005 | 01:49 PM
I had one slight problem... I used glow in the clear dark paint on it, and it ate the paint off. Now i have to redo it. All i did was take a knife and scratch tiny hole on top of the red paint, that way you still see the red bird duing the day, and at night.. WOW... Then wired a red light from autozone into the license plate light. Then i use aluminum foil to block the light from shining below the lens. and from around the keyhole. the aluminum foil also acts as a reflective backing that directs the light up to the uper parts of the bird. I'm tellin ya, it looks sweet!
Old Nov 18, 2005 | 01:59 PM
also, to give the taillights an interesting effect, and slightly brighter, remove the lens and use 3m spray adhesive and glue aluminum foil to the back around the bulb. Soon i am putting in Red leds.. DO NOT GET WHITE LEDS FOR TAILIGHTS!! They are not near as bright as red, because it is not filtered like the white.
Also get leds and have many many leds in one bulb, that way it disperses the light and fills the entire lens.
This looks like a good one.
Old Nov 18, 2005 | 04:14 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Even those multiLED bulbs do not put out the same amount of light as a standard 1156/7 bulb. Unless you take the time to make an LED board with some superfulx LEDs or similar you're not going to get the same output.
Old Nov 18, 2005 | 04:30 PM
they also turn on and off instantly
Old Dec 10, 2009 | 10:30 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: firebird taillight mod
Bringing it back!!!!
need some pictures of this anybody anyone?
Old Dec 10, 2009 | 10:52 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
pictures of what?
1992 Trans Am
May 10, 2023 07:19 PM
PATRIOTIC1911
Northern Great Plains and Rocky Mountain
Oct 7, 2022 10:38 PM
jhawkeye
May 25, 2022 06:33 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
matthew911
Aug 12, 2015 09:38 AM
