Possible to have T-Tops cut in?
Car: 1991 RS
I was wondering if it is possible to have t-tops cut into a hard top camaro. Wondering if anyone has had it done, or how much it would cost.
Car: 2011 Ranger
Engine: 2.3L
Transmission: Stick - Shift like a man!
I don't know the cost off-hand, but their have been people that did it. From what I've heard, the job was not done well and the T's ended up leaking
Good luck with it if ya go for it
Good luck with it if ya go for it Member
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
The best way to approach it would be to cut a t-top roof off of a donor. Then cut your roof off and weld the t-top one in place. Alot of people have asked this question and in the long run don't end up doing it since its not worth it.
Instead, the easiest way would be to buy a t-top car with bad interior and no motor and just swap your good parts over to it.
However if you still want to do it, do a search in either the body or fabrication sections
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
might as well make it a traga top if you are going through all that trouble. imo, not worth it.
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
check this link out
http://www.markscustomkits.com/t-top-conversions.htm
we do stuff like that at work all the time. its easy, just takes some time. (coming from a 17 year old).
Car: 95 Camaro Z28
Transmission: 4L60E w/ shift kit
Axle/Gears: 3.23s
Originally posted by johnnyq5021
check this link out
check this link out
Car: 1988 Pontiac Formula 350TPI HARDTOP
Engine: 04- 350 Crate Motor with Crane Cam
Axle/Gears: 10 Bolt Posi 3.73:1
T Tops
F Body Camaro's and Firebirds with the T Top option make the Car Body Structurally Unsound . The Body can warp and twist under High Performance Driving . The Hard Top F Bodies are for Racing , the T Tops for Show . Just Open a Window Dude and be Happy !
Roll Cage
Are we Talking Street or Strip here ? Most People drive the F Body on the Street , and I do not see Many with renforced Roll Bars in them .
Car: 1987 IROC-Z
Engine: 5.7L V8
Transmission: TH700R4
Axle/Gears: 3.73 Borg Warner
Re: T Tops
http://www.hardtail.com/
Car: 2011 Ranger
Engine: 2.3L
Re: Roll Cage
Car: 1991 camaro rs
Engine: v6 3.1
Transmission: auto
the amount of steel above the window is different. its would be stupid to have a car with half the roof and the same amount of structural bracing. it wasn't designed for it.
if your car rolled youd be F***ed up imo. just think about it
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
IROCZDAVE (88-L98)
Sep 6, 2015 06:23 AM
