Want Parking Lights BRIGHTER!
Old Feb 21, 2001 | 08:23 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I was wondering if there was anything I could do to make my parking lights brighter. I don't have the foglights so I drive with the parking lights on (looks good, but would look better brighter). Are there any brighter bulb replacements or should I go to a yard and get the foglight grill and install that!
thx guys
Old Feb 21, 2001 | 10:53 AM
scauffiel's Avatar
You can get 2057 bulbs to replace the 1057's in there - be aware that they run hotter (especially if they're on all the time) than the others. I believe they are 20 watts vs. 10 watts. I damn near melted my "daylights" when I wired both elements to be on all of the time. Without cooling they can get damn hot.
Steve
Steve's Trans Am Temple
Old Feb 21, 2001 | 11:27 AM
Mr. IROC-Z's Avatar
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Ok....I will now give you the secret...but
there are costs to this.
You can make your parking lights look just
like the newer Vettes and Camaros (the ones
with the always on parking lights).
Basically, you reverse the polarity of the
lights....switch the positive wire to the
negative and vice versa. Turn your parking
lights on now....wow...what a shine huh!
Now...here's the cost....you will no longer
be able to use your front turn signal.
When you signal the light on your dash
will stay on...you'll have to flip it up and down manually to signal a turn. Yoor front parking lights will not flash...only your
side markers and the rear lights.
I have done this to my car and it is
absolutely wicked! I always drive with my
parking lights on now because they are as
bright as the vettes!
Tommy
P.S I will try to get a picture for you
guys tonight.
Mr. IROC-Z
WWW.IROCZDESIGNS.COM Because looks are everything.
Old Feb 21, 2001 | 02:37 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Thx guys,
I might try to get those bulbs but thx for the heat warning. Where do you get those? Would it be easier to install some after market PIAA lights in the grill or maybe go to a junk yard and get the grill with the factory lights? Would this be a better solution and a nicer look?
Old Feb 21, 2001 | 04:22 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I also wanted my parking lights brighter cause I really like the look. I noticed the lights have clear lamps and amber bulbs but in earlier model Camaros (such as the 86? I believe) have orange lenses. Would those lenses fit a 92 RS? Then I can just replace the bulbs with clear ones and but the orange lenses on. Would that be any brighter?
1992 Camaro RS
305ci automatic, all stock til I get some cash.
My 1992 RS
Old Feb 21, 2001 | 04:52 PM
Monkie's Avatar
What if you drilled SMALL holes in the lenses to let air get in there to cool the bulbs? Just an idea!
1992 Camaro RS 3.1L Check my cars out! http://hometown.aol.com/stopsign696/...age/index.html
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
AIM screen name - Stopsign696
Kills:
95 (****) Probe GT,94 Mustang GT,91 CRX (dont ask me why he raced me),2nd Gen Z28 (350) haha to you V8 guys!,1992 RS 305 TBI (good race),First Gen Integra, Old Escort LX, 80 something Fbird
More to come
Old Feb 21, 2001 | 04:56 PM
Monkie's Avatar
double post
[This message has been edited by Monkie (edited February 21, 2001).]
Old Feb 21, 2001 | 05:42 PM
JPrevost's Avatar
Car: 91 Red Sled
That's what I was thinking, drill a few holes. The housing is thick so I don't see a problem with a few holes. Only problem would be water vapor. You'll need someway to drain any of the water that might get trapped.
, Jon (91 RS too many mods to list)
Dale Earnhart, you have done so much, you will be missed.
Old Feb 21, 2001 | 09:36 PM
Monkie's Avatar
No see thats really the problem I think. Mine doesnt have it but most fbodys have the water inside the parking lights problem. I think this actually would help out. Drill the holes and take it for a spin for about 20 mins and that should dry the water inside the lights right?
Old Feb 21, 2001 | 09:43 PM
RARE-ROC-Z's Avatar
ok if you drill the front drill it in the top of the lense. and then take the whole lense out and drill 2 small holes in the bottom for water to leak out through. try and make the drill holes on the top point down at a 45* angle since it will be less likely to get water splashed up in there as easy. and i think it might work but when you drive it might whistle also. have fun with it. and try it on some junkyard pieces before you do it to your prized posession.
1990 IROC-Z L98 350 TPI
AFPR 49PSI, GUTTED AIR BOXES, K&N, RAM AIR, UNDERDRIVE PULLEYS, PORTED PLENUM, B&M SHIFTER, 3.23 LIMITED SLIP, DUAL CATS, STOCK SUPER TURBO EXHAUST, COOPER COBRA XST's
ALUMINUM DRIVESHAFT OFF A 98 Z IN GARAGE READY TO GO ON. ALSO MAGANFLOW MUFFLER READY FOR INSTALL
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
MUSTANGS...ONLY 4 LUGS....HAHA THAT IS HILARIOUS.
Old Feb 22, 2001 | 01:28 AM
Jza's Avatar
Jza
2057 or 2157 (i think) in the fronts instead of the 1057 or 1157, and 168 in the sides instead of 194.
Old Feb 22, 2001 | 08:50 AM
scauffiel's Avatar
Can you guys drill holes from behind? By that I mean in the rear of the case? If you were to drill a couple up high in the back the heat would cause any water to evaporate and leave via those holes...
Least I think it would.
Steve
Old Feb 22, 2001 | 08:58 AM
RenoLB8's Avatar
If you do rill the lenses, do them at a pretty shallow angle, so the holes will be really long, but then looking at it, a person would have to be at the right angle to see that there are holes.
-Reno
Old Feb 22, 2001 | 09:05 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
also you could replace your bulbs witht he 2057kr they are a l ot brighter
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
CHECK OUT MY SITE <A HREF="http://www.fbody.com/members/bigdaddyshawn/
MUSTANGS" TARGET=_blank>http://www.fbody.com/members/bigdaddyshawn/
MUSTANGS</A> SUCK
Old Feb 22, 2001 | 09:06 AM
nosaint's Avatar
Car: 1986 Trans Am
I have an easier suggestion.
go to www.designtech-intl.com
and purchase a set of their "Super Bright"
bulbs.
I bought a set and they are brighter. One burned out the next day but the other is still going. Not too sure what to make of that but its another option.
1986 Black & Gold WS6
Trans AM...The Muscle Car Lives
...Its just not at home at the moment...
www.members.home.net/nosaint
Old Feb 22, 2001 | 11:48 AM
Car: 1989 IROC-Z
Engine: 383 stroker
Nosaint: Are those bulbs any hotter?
1992 Camaro RS
My 1992 RS
Old Feb 22, 2001 | 04:34 PM
nosaint's Avatar
Car: 1986 Trans Am
Im sure that they are but they havent melted anything yet. I only have them in the front park lights so far.
Old Feb 22, 2001 | 06:22 PM
gregz28's Avatar
Dont drill your lenses. You'll find yourself buying new ones. Even if you drill them on the bottom for the water to seep out, they will ALWAYS be fogged up with moisture, and it looks horrible. Trust me, I have experimented for you. I suggest the reverse polarity thing, or the brighter bulbs. I ended up buying new lenses, and bought bright clear bulbs. I also keep them very clean by rubbing them down with 1500 grit compound and wax them on every wash.
91 Z28 305 tpi
plans for 383
flowmaster cat-back
Ram air to K&N cone
http://www.fbodyeurope.cz28.com
[This message has been edited by gregz28 (edited February 22, 2001).]
LittleFranks
Sep 17, 2015 12:22 PM
Jk_Under
Sep 2, 2015 10:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
