Cheap fix to remove these marks?
Old Jan 29, 2006 | 01:59 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Is there a cheap way to remove these marks, I dont want to have to paint the car to remove these marks cuz that would cost a lot of money, and I'm really more concerned with getting the car fixed and performance more than appearance at this point.
Old Jan 29, 2006 | 02:51 PM
Lazer's Avatar
Car: 1989 Iroc-Z / 1985 Camaro
Engine: 5.7L 350 / 2.8L V6
McGuires 3 step seems to work pretty good. It won't make it look perfect but you'll notice a huge difference. You can find it at your local autozone or some place like that.
Old Jan 29, 2006 | 03:58 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
invest in a buffing wheel and some rubbing compound / polish.. that will get pretty much everything on the surface out. If you need to go deeper, 1500/2000 grit wetsand. then buff it back out. Then touch up any places where the paint is chipped.
If it is mostly gunk/glue on the surface, rubbing compund and some elbow grease should do the trick
Steve78LT
Feb 24, 2016 12:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
mustangman65_79
Aug 7, 2015 09:55 PM
Leggman1
Aug 6, 2015 04:15 AM
