what to clean spark plug wires with?
Old May 16, 2006 | 03:23 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I was going to use some good ole formula 2001, but seeing what everyone else uses, maybe some one have a better idea
Old May 16, 2006 | 03:36 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
WD-40 works good!
RGZWS6's Avatar
I've always liked brake/carb/choke cleaner on a wrag. Spray the wrag first then grab the wire with your wrag. Should only take a few swipes before it's good as new!!
This method is good for all sorts of pesky stains on carpet as well as scuffs on door panels
Old May 16, 2006 | 11:48 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Gojo hand cleaner, the white creamy stuff. Put some on a rag and wipe away...removes all the grease and stains. In fact I use it on all rubber hoses and plastic under the hood. Makes it look factory new instead of that shiny, greasy Armorall look.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
